SLEEPER AC HELP
Discussion in 'Ask An Owner Operator' started by thecubantrucker, Sep 18, 2019.
  1. thecubantrucker
    thecubantrucker Light Load Member
    145
    89
    Jun 2, 2019
    ok guys 2002 freightliner century my ac in front working great so it was the rear one last night till I woke up and felt it not as cold I opened up the bunk the rear blower working fine I can hear it turn off and on when I hit the switch but theres no AC or anything coming out of the bunk air ducts any idea
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    The sleeper will have its own expansion valve, you need to check that and make sure it’s working properly.
    xairx and Ezrider_48501 Thank this.
  4. Espressolane
    17,538
    107,426
    No air flow from the vents? Or just not cold?
  5. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    check the ac lines under the cab. also check the drain tube. right rear corner. make sure the drain tube isnt stopped up. use your fingers to open the end of the rubber tube. you want it to drain like a hose. check to see if one ac line is hot too the touch and one is cold. this is with the ac on high. also check ac bunk filter on the box. after this is done. then its time to pay someone to put gauges on it. if the expansion valve is plugged. this will cause the problem also. but the first 3 things i would check is the lines and the rubber drain tube
  6. thecubantrucker
    145
    89
    Jun 2, 2019
    thank guys it was loose cable I guess moved them around and working again
