sleeper ac problem?
Discussion in 'Kenworth Forum' started by dmw, Sep 29, 2011.
  1. dmw
    dmw Bobtail Member
    4
    Stockdale
    I have a 2001 w900 sleeper ac is getting cold but is not blowing as hard as it should. I have changed the filter and used a coil cleaner on filter side of fins. What else can i do to have more air flow. Cab as is working fine. thanks in advance for any advice. I also have 2 springs on sleeper bed broke where can I get replacements. I have tried local upholstery shops with no luck.
  3. Big John
    Big John Road Train Member
    2,022
    1,521
    Oct 7, 2006
    Oklahoma
    My 2001 T800 I took the shop vac and did a good cleaning of vents and it blows a lot better, in fact I leave it on the first setting because it will freeze you out of their.
    dmw Thanks this.
  4. KW Parts Guy
    KW Parts Guy Light Load Member
    230
    78
    Jul 16, 2011
    A new matress will probably only run about 250 or so.
  5. Hanadarko
    Hanadarko Independent Owner/Operator
    2,962
    927
    Oct 1, 2009
    Midwest
    More air flow...Hmmm. Not sure on that one...but...I replaced the entire HVAC unit under the bunk (it was rotting away due to an undiscovered coolant leak).
    $1700 for the complete assembly from KW. - Literally just drop in place.
    Now, before that...last year I was getting ice cold air in the cab but the sleeper was much warmer. Turned out it was the expansion valve in the sleeper. $35.
    Once I replaced that, then I went under the rig and insulated all of the cold AC lines to the sleeper.
    They are bare which amazed me since they travel a good distance.
    Now, like Big John said....I can get ice cubes falling out of the vents :biggrin_25520:...KW makes one hell of an AC unit, thats for sure..
    dmw Thanks this.
  6. dmw
    dmw Bobtail Member
    4
    Stockdale
    Thanks everyone for all advice have a wonderful day
  7. Charles Hill
    Charles Hill Bobtail Member
    I'm sleeper ac blower is blowing but hardly any air coming out of the vents
