sleeper AC question
Discussion in 'Kenworth Forum' started by clumsy calamity, Sep 30, 2013.
  1. clumsy calamity
    clumsy calamity Bobtail Member
    9
    Aug 5, 2013
    Hi everyone!
    I have a 2011 kw t660 with a studio sleeper, I do not have an APU yet, so I have to idle my truck for AC. I am down in Florida
    Right now, and naturally the air blowing in the sleeper is not as cool as it has been, still very warm and doesn't cool down
    the sleeper. However the ac blowing up in the front is just fine. Does anyone have any ideas on what could he causing this?
    Thank you!
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    low on freon or heater letting hot water past cut off valve.
    DoneYourWay Thanks this.
  4. VisionLogistics
    VisionLogistics Road Train Member
    1,551
    978
    Dec 8, 2011
    Jellystone
    Air blend door in the ducting under the bunk not closing properly, thus allowing the cool air to mix with hot, compromising the cooling capability.The HVAC under the bunk is a separate system from the one in front, but uses the same compressor on the engine, therefore requires the engine running, and the front AC turned on (to control the compressor).
  5. snowwy
    snowwy Road Train Member
    20,590
    13,308
    Jul 6, 2009
    try turning off your water valves to the sleeper. if the engine has them. it's what fixed my bunk a/c
  6. Casual Trucker
    Casual Trucker Medium Load Member
    495
    326
    Sep 7, 2012
    We have an AC Fan that run off of the 800 watts inverter & it does a fine job circulating the air around the cab.Also make sure if you have a recycle button for the AC on your dash to use it. Which will only recycle the cool air inside the truck and stop drawing humid air from outside the cab.
  7. LadyTrucker99
    LadyTrucker99 Heavy Load Member
    729
    130
    Jan 15, 2008
    Lexington, NC
    I have the same issue in my 2013 t660..had kenworth replace the blender door but still rear a/c don't work properly..Its been to kenworth 4 times..still not fixed and they cant figure it out either..LOL
  8. Heritage661
    Heritage661 Bobtail Member
    27
    5
    Apr 4, 2016
    Thanks for post have they found out yet mine is the same?
  9. Heritage661
    27
    5
    Apr 4, 2016
    Need help the sleeper just blows out hot air the truck has a new compressor, drier, and expansion valve. Does the sleeper have different Ac components? The compressor stays engaged while the sleeper is on I even shut off the front Ac in the cab any comments would be greatly appreciated
  10. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,144
    Apr 1, 2011
    Broomfield, CO
    The most common cause of this problem which I've encountered on the T660 was the heater control valve under the bunk. There should be some coolant lines coming off the right side of the engine.. they should have valves attached to them... identify the one which goes to the sleeper heater core and close off all flow through the valve. If the bunk AC suddenly gets cold at that point, the heater control valve is your culprit.
