Sleeper Fan Switch Flashing
Discussion in 'Volvo Forum' started by 325TahoeSS, Sep 29, 2012.
  1. 325TahoeSS
    325TahoeSS Light Load Member
    150
    71
    Feb 11, 2012
    Roma, Tx
    My sleeper fan switch just started to flash & the sleeper panel is making a beeping noise! My cb & lighter plugs stop working then they start up again! Anyone ever ran across this problem before?
  3. peterd
    peterd Medium Load Member
    349
    365
    Jan 7, 2012
    St.Catharines ON
    Volvos have a low voltage protector built into their system. It is part of the bunk control panel.When battery voltage drops below 12.2 volts the alarm goes of any many electric circuits shut down.Either the module is bad or the truck has some bad batteries.
  4. 325TahoeSS
    150
    71
    Feb 11, 2012
    Roma, Tx
    The voltage is reading 11.8 with all my chicken lights on & both front & rear AC going! I'll check the batteries tomorrow! The truck had been setting in the shop for 2 weeks!
  5. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    Idle it for 15min and see how long it takes to turn back on.
  6. peterd
    349
    365
    Jan 7, 2012
    St.Catharines ON
    Sounds like your alternator is not putting out enough with all your lights on.With engine running with everything on alternator should put out at least 13.6 volts.
  7. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    Volvos new room room: The shop floor.
  8. 325TahoeSS
    150
    71
    Feb 11, 2012
    Roma, Tx
  9. jasko
    jasko Bobtail Member
    7
    I have 2006 Volvo 670 D12. I don't have electricity in my bunk - light is not working, only clock is working. First I had sleeper fan switch flashing. So I replaced all batteries and alternator. I checked all fuses, all are working. Is there anything else I need to check to fix this?? Thanks.
  10. jasko
    7
    Is any chance I can contact Pablo-UA? Thank you!
  11. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    may be bad grounding makin battery protection system active
