sleeper florescent light
Discussion in 'Peterbilt Forum' started by kyletg23, Apr 7, 2014.
  1. kyletg23
    kyletg23 Bobtail Member
    23
    Oct 10, 2013
    My 2000 379 flattop has a blown ballast for the florecent light in the bunk. Is ther an alternative to the two hundred dollar pete replacement, say LED like the new KW one?
  3. KAK
    KAK Medium Load Member
    518
    2,073
    Feb 10, 2012
    Ne
    I bought the led one for my 2000 Pete at the KW dealership. It was right around $100. Plugs right in and last forever
  4. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    what is the p/n for the ballast?
  5. boneebone
    boneebone Road Train Member
    2,296
    2,367
    Mar 13, 2009
    When mine went out in my Volvo, the Stealership wanted $200+ for a complete Light Assembly, (the fixture is Non Serviceable), so I went to a Salvage Yard instead and bought a complete Used Assembly with bulb included for $20.00.
  6. Alaska76
    Alaska76 Road Train Member
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
  7. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,179
    Apr 20, 2011
    Dahlonega, GA
    They make an LED replacement, I've got it in my truck and it's bright.
  8. kyletg23
    23
    Oct 10, 2013
    Thanks KW Unit it is.
  9. generallee
    generallee Medium Load Member
    512
    441
    Jan 4, 2014
    mine like to come on by itself and sometimes won't turn off with either switch. Short somewhere?
  10. wagasser
    wagasser Bobtail Member
    32
    7
    Nov 5, 2013
    Did you ever find out the part # for this or what was the LED replacement one?
    thanks
  11. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Grote makes a light, #61371 that is the same size and same bulbs for 1/2 the cost of a Pete one. You could make it work or just use the ballast from it.
    Or TRP makes an LED, #LL073105 and is only $35. It is a lot smaller than the flourescent, but brighter. You can gut the stock one and they fit inside, or you can make something to cover the bigger hole to mount it. I seen someone use a piece of aluminum diamond plate cut to fit where the old light was, then mount it to the diamond plate. It looked nice and was brighter. If you mount it inside the old housing, it's not any brighter than the stock one, the lens dulls it back down, but it looks stock that way. You can't get to the on/off switch that way either, so not a good option if you don't have the wall switch.
    wagasser Thanks this.
