Sleeper lighting problems
Discussion in 'Freightliner Forum' started by Proex118, Jan 3, 2015.
  1. Proex118
    Proex118 Bobtail Member
    7
    I have a 2012 cascadia and just the other day the sleeper lights went out but everything else is normal I took my truck to freightliner and got it look at but they could not find the problem and I have put batteries and all new fuses in it and still the lights won't come on what else could it be I need to know ASAP
  3. Surfer Joe
    Surfer Joe Heavy Load Member
    960
    1,089
    Feb 27, 2011
    Cape Ann, Massachusetts
    Did you replace the correct fuse?
    Reason I ask is because the fuse for the sleeper light is on a really obscure system; meaning that it's location is not marked in an obvious manner, nor, is it even marked specifically. It is on a circuit that will seem totally unrelated to the sleeper light, therefore, it will be very difficult to pinpoint.
    You may have to replace ALL the fuses to eventually replace the correct one.
    Perhaps a qualified mechanic that has the correct experience replacing this fuse would be your best bet.
    Proex118 Thanks this.
  4. Proex118
    7
    Yes I think we have replace all the fuses in the cab behind the glove box could it maybe be the mega fuse junction box my truck is on the road wright now and when it gets back I need to put it out of service
  5. Proex118
    7
    Come on people I need to know how to fix this problem freightliner told me if it's the Sam cab than it will cost me $1,200
  6. MachoCyclone
    MachoCyclone Road Train Member
    4,417
    3,907
    Jun 13, 2012
    Texas
    Seriously, you are going to put your truck out of service for something stupid as the sleeper light? With everything running through the computer on these trucks now a days, save yourself the $1200 and buy a lamp or two that you can plug into the 12 volt outlet.
    Rideandrepair Thanks this.
  7. Proex118
    7
    We'll um I have to make sure all my trucks are fixed wright and that every part of the truck is working because it could be a fine since it's not working #######
  8. MachoCyclone
    4,417
    3,907
    Jun 13, 2012
    Texas
    I really doubt a dome light is a violation.
  9. Proex118
    7
    U would be surprise we have a lot of dick heads In Kentucky
  10. frt60
    frt60 Medium Load Member
    312
    266
    May 22, 2014
    Had the same problem on my 01 classic. Fixed when the trailer light short was repaired .sleeper lights were on the same breaker and breaker was kicking.thats all the help I can give
  11. tommymonza
    tommymonza Road Train Member
    4,519
    12,849
    Sep 10, 2013
    S.W. Florida
    Go buy a 20 dollar Ohm and Voltage Tester along with a Quick prick 12 volt tester and sit down on the internet and do searches rather than Gaming and figure it out for yourself.
    This is another BIZ that blows me away that people get into that is highly mechanical and those that choose to get in it can barely figure out why the light bulb in their bedroom at home burned out.
    No offense to the OP.
