Sleeper modification questions
Discussion in 'Experienced Truckers' Advice' started by tommymonza, Dec 15, 2014.
  1. tommymonza
    tommymonza Road Train Member
    4,519
    12,848
    Sep 10, 2013
    S.W. Florida
    Is it against any DOT laws or anything else out there that says you as an individual are not allowed to gut and refit the inside of a sleeper as you see fit?
  3. 315wheelbase
    315wheelbase Heavy Load Member
    783
    601
    Oct 26, 2014
    go read the regs ..law says there is a min size ,,you can modify any way you want
  4. tommymonza
    4,519
    12,848
    Sep 10, 2013
    S.W. Florida
    What about cutting one and sectioning in another foot or 2 if the current frame length permits it?
  5. Flybynight041
    Flybynight041 Medium Load Member
    358
    271
    Dec 9, 2014
    It's not just frame length you need to look at, but also weight limitations. Without knowing the specifications of your truck and the new sleeper, this is kinda like playing darts blindfolded.
    There should be a placard on the drivers side door that'll tell you the manufacturers specifications. As long as you keep your weights in adherence with the bridge formula and those specifications, you should be legally alright.
  6. kemosabi49
    10,452
    44,500
    Jan 13, 2013
    SW Arkansas
    I have seen a lot of modified sleepers over the years. Some of the homemade type didn't turn out so well but a lot of them looked ok. You can spend thousands of $$ on a custom sleeper from companies like Legacy Sleepers. Some of them do standard sleeper conversions too. Like Flybynight041 says, watch your specs.
  7. icsheeple
    icsheeple Trailing the Herd
    2,548
    2,552
    Nov 1, 2013
    Kansas City, KS
    I've seen two sleepers welded together back to back. Wish I got a pic of that thing.
  8. tommymonza
    4,519
    12,848
    Sep 10, 2013
    S.W. Florida
    I used to build lightweight custom sportfishing boat out of Juniper wood and Epoxey saturated fibergalss so I believe I could keeo the additional length very light by doing it with a foam or balsa structural core with fiberglass..
    Only need a additional 2 feet on a 84 inch sleeper so there would be room to add a combination head and shower room and a small galley with a sink and burner across from it ,maybe add 500 lbs at the very most.
    Would that be too much?
    Having lived with IBS for 30 years and not seeing it get any better a personal head in a truck is not a luxury but a necessity.
  9. fortycalglock
    fortycalglock Road Train Member
    6,150
    6,581
    Jun 25, 2011
    Tourist Town, FL
    You can do anything you want as long as it meets DOT minimums which is basically size of bed and height above bed. You can build a 40,000 pound truck if you want. There is add on shower and toilet system that you put behind your sleeper that might be the easiest way for you. If you don't run Cali, there is a tremendous amount of big sleeper trucks for sale right now that are 07 and older as a majority of big sleepers are team trucks that need Cali.
    http://www.aatrucksleeper.com/shower/
  10. barroll
    barroll Road Train Member
    1,096
    544
    Nov 23, 2010
    Southwest Michigan
    Why add 2 feet when you can add 9? It's been done for decades, and fortunes have been spent and made on it.
    This one was built in the 1970's and was gutted when I bought it. Never a peep from the DOT about it.
    dieselfuelonly and icsheeple Thank this.
  11. dieselfuelonly
    dieselfuelonly Road Train Member
    2,475
    5,086
    Nov 12, 2012
    Chapel Hill, NC
    Very cool, how does the cab seal to the sleeper?
