Sleeper Seal
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JimmyWells, Jul 14, 2017.
  1. JimmyWells
    JimmyWells Road Train Member
    1,000
    1,078
    Apr 7, 2016
    How much of a job is it to do a sleeper seal on a 94 W9 non-Aero cab flat top?
  3. bigguns
    bigguns Road Train Member
    2,846
    6,853
    Jun 13, 2013
    Omega,GA
    Not bad. Just time consuming. Lots of screws to remove. Do Not use any kind of sealant of the boot.
    JimmyWells Thanks this.
  4. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    So no sealer at all. It just screws on?
  5. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    I got everything apart today, yes lots of screws. Maybe it's just me but I don't see how it actually seals. Water drips in right around the screws. Doesn't seem right to me to have no sealant under the rubber. Otherwise the boot looks good. I was thinking of covering all the top and side screw heads with some sort of sealant.
    SAR Thanks this.
  6. TGUNKEL
    TGUNKEL Light Load Member
    229
    160
    Mar 16, 2013
    Spokane,Wa
    When mine was leaking, all I did was go around and tighten all the screws, problem solved.
  7. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    I did that today in hopes it would fix it. Just doesn't seem like a solid lasting option though. Those screws will come loose again soon.
  8. TGUNKEL
    229
    160
    Mar 16, 2013
    Spokane,Wa
    I did mine 4 years ago, no leaks yet.
  9. Sublime
    Sublime Road Train Member
    1,529
    1,896
    Jan 18, 2013
    Twin Cities, MN
    It's pretty easy. I ended up having to put some sealant along the top but beyond that nice and dry.
    JimmyWells and TGUNKEL Thank this.
  10. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    Hearing they stayed tight for you gives me hope. It's just I saw a little sealant under there when I was looking around. I think the previous owner may have had an issue as well. I'll keep and eye on it. So far so good!
    SAR Thanks this.
  11. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    Some of the screws were stripped so I had to use new ones that were larger in diameter. Decided to do all of them. If it leaks now, then something else is going on.
    TGUNKEL Thanks this.
