Sleeper Turbo Wing for W900, will it improve fuel mileage?
Discussion in 'Ask An Owner Operator' started by Adamali21, Apr 20, 2021.
  1. mmk trucking
    mmk trucking Light Load Member
    145
    122
    Mar 6, 2016
    Bread is bad look at the size of the truck drivers
    Rideandrepair Thanks this.
  3. AModelCat
    145,376
    Heavy spec W900 with a Cat. You don't buy a truck like that looking for fuel economy.
  4. kemosabi49
    10,011
    41,498
    Jan 13, 2013
    SW Arkansas
    Lol. Like the Turbo3000 or whatever it was. Made a good sliding sinker.
  5. Long FLD
    Long FLD Road Train Member
    9,644
    37,545
    Mar 4, 2015
    You’d be better off finding a used factory fairing in a salvage yard versus the wing.
  6. special-k
    special-k Road Train Member
    1,516
    3,247
    Dec 27, 2008
    Southern Ontario Canada
    On a w900 like yours with the raised bunk l don't think you'll see a significant gain. A wing should be a little better that the factory style duct bill/whale tail but at the end it'll come down to what you prefer looks wise.
  7. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,039
    Nov 18, 2014
    Land of local
    Slow it down a few mph. Forget the wing
  8. Long FLD
    9,644
    37,545
    Mar 4, 2015
    Or swap rear ends. I think he has 3.90 so going to 3.36 would make his Acert a lot happier.
    Rideandrepair and Brettj3876 Thank this.
  9. Brettj3876
    11,257
    54,039
    Nov 18, 2014
    Land of local
    Or tall rubber if he doesn't already have it
  10. special-k
    1,516
    3,247
    Dec 27, 2008
    Reflash the ecm would probably be the best all around solution.
  11. Long FLD
    9,644
    37,545
    Mar 4, 2015
    He had a whole thread a while ago about buying this heavy spec truck and swapping tires and such to get his 5th wheel height down to pull a dry van. If I recall he’s pretty gear bound and should be running about 60 to be where an Acert likes to be.
  12. AModelCat
    145,376
    I'll never understand why so many folks buy a truck, then spend so much time and money to make it into what they need. If fuel mileage is the goal, buy a VNL or a Cascadia, not a brick built to haul 100k+ loads.
    86scotty, Brettj3876 and Rideandrepair Thank this.
