slide tune antennas
Discussion in 'CB Radio Forum' started by Bum With Shoes, Nov 16, 2007.
  1. Bum With Shoes
    Bum With Shoes Bobtail Member
    Baltimore,Md
    put my galxy99 into freightshaker day cab tried half dozen different antennas and swr's still not acceptable....anybody try the wilson slide to tune?
  3. thetez
    thetez Medium Load Member
    380
    24
    Jul 10, 2006
    it may be the ground... check it, make sure the mount is grounded, or try grounding the antenna to the mount... im sure people are gonig to get more in depth on grounding.... but i have a wilson silver load with the "slide tune" it works great, ive got my dual antennas tuned to around 1.1
  4. Bum With Shoes
    Baltimore,Md
    definitely a ground issue.....failed to mention i do slipseat often seems each truck gets different swr readings all ranging from 2.0 to 3.0 reason why i was thinkin bout the slide tune. you seeing 1.1 is that an accurate swr measurement? just curious if the slide tune gonna take any transmit power from radio?
  5. thetez
    380
    24
    Jul 10, 2006
    Yes its accurate, SWR is not a locked number in a mobile set up.. it will jump a little higher sometimes, but for the most part its around 1.1 to 1 Take any transmit power? it wont require any extra power, the better tuned the antenna is the better transmit and receive you will have
  6. Bum With Shoes
    Baltimore,Md
    gonna research this some more.....thanx for your reply
  7. capnhector
    capnhector Light Load Member
    if you keep having ground issues and slip seat you might spring for a no ground antenna you have to use the coax that comes with the antenna but then you never have to worry about grounding. just tuning it up.
