Here is where I need a expert truck drivers advice. The company I'm applying with hauls a lot of heavy freight. What is the best way to balance a load using the 5th wheel and trailer tandems. Also, if you are heading into C.A. fully loaded and the trailer tandems to the rear. What do you do since C.A. law only allows for 40'. Thanks to all that can answer this question your advice is really appreciated. . .
Sliding a trailer tandems the best way to do it. . .
Discussion in 'Experienced Truckers' Advice' started by Bigowl, Dec 13, 2009.
Page 1 of 6
You should rarely ever have to mess with the fifth wheel. As far as the tandems go put them right under the last pallet on the trailer. That usually will be about right. You still need to go weigh it to make sure though. As far as CA I can't help you. I never go west of the MS.
Like the other driver said, get your 5th wheel set where it keeps your steers legal then don't mess with it unless absolutely necessary (extremely nose-heavy loads, generally).
If you can't make the bridge limit in Cali you shouldn't run there unless you like paying tickets and waiting for a company with another trailer and some lumpers to come out and rescue you at a coop. If you can't make it legal, make the shipper take some of the load off or reorganize the load so heavier pallets are up front to make you legal.
Good luck,
JimBigowl Thanks this. -
When you pickup a load that will be going to Ca. the tandems have to be in number 5 hole or less .
If you can not get the load to scale legal in number 5 hole or less on a 53' trailer , the load will have to adjusted or reduced till you can get "CA legal " . So the do not drive 60 miles away before getting on a scale to check ! You may have to go back and get the load reworked so you can get legal . Worse yet the place is closed when you get back there and they are closed !!! Been there !
Also if you must slide a 5th wheel lower the landing gear down somewhere out of the way of others so you do not get in anyones way .
Next now that you have wieght off the fifth wheel it will slide much easier and your clutch and driveline will thank you .
Hope some of this helps you , good luck to you .
I keep my 5th wheel centered directly above the drives, keeps the steers legal and allows for a smoother ride. And I have yet to adjust it for weight.
As far as CA bridge law, you're allowed 40' from the kingpin to the center of the rear trailer axle, and yes they will measure it.
So far I've been pretty lucky with what BubbaMark said about the last pallet above the tandems, just make sure you weigh and double check it. -
Drivers are there any other states that have strict bridge laws like C.A. and who would you consider to have the most strict bridge laws. Thanks
Watch georgia and florida.......and the fines in florida HURT !!
While we're on this subject, it will be to your advantage to learn how to load your trailer. DO NOT bump the dock and climb into your sleeper and trust the forklift guy to load you legally. And be very aware of loaders that say they've never had one come back. Those are the ones that will have you with 37,000 on your drives/tandems. Assuming you are allowed on the dock, find out how much weight they are putting on you, how much each pallet weighs etc. You will get loads that have 2500 lb pallets as well as 1200 lb pallets. Ask how many pallets total you are getting. Usually pallet weight is not on the paperwork. (50 lbs each), so 22 pallets will mean 1100 lbs not noted. I am talking heavy loads here. Be very careful when loading mixed produce. A pallet of carrots weighs more than a pallet of leafy greens. It will take some time to get experience with weight distribution, but you need to monitor the loading process and take notes. Also, you really should be counting your freight on. If you sign for 1200 cases and only have 1150 at the consignee, you pay out of your pocket. The exception would be a pre-loaded, sealed trailer or a swap.
JustSonny, Bigowl, shadowfax and 1 other person Thank this. -
Most states have bridge laws. Get you a trucker atlas. In the front they have the bridge laws for every state. Most states in the NE have very strict laws but none are as strict as CA.
Get a 100' tape measure and a pair of lock jaw pliers. Do NOT trust the 5 or 7 hole theory as the distance between the holes can differ from one manufacturer to another! Paid for that mistake at Banning years ago!
MEASURE to be sure! Use the lock jaws to clamp the end of the tape measure to the side of the trailer across from the king pin and then measure the trailer back to the center of the tandems and put a small mark on the trailer or at the 40' mark. Some companies have already done this for you. My last fine for being 1 inch too long was $168.00 but that was back in the late 90's and "might" have change for the worst to help pay off all their debts!Bigowl, MCss, future driver and 1 other person Thank this.
Page 1 of 6
