Sliding in rain too easily
Discussion in 'Questions From New Drivers' started by brandoo, Nov 17, 2014.
  1. brandoo
    brandoo Bobtail Member
    14
    8
    Nov 17, 2014
    I am a semi truck driver and lately it's nearly impossible to drive in any type of rain, even when it's only misting out. I drive at a mere 40 mph once it begins to drizzle but I still am sliding. It got so bad that I had to pull over and wait for the roads to dry up before I could even consider continuing driving. Other semi's, empty trailers & flat beds even were having no trouble and flying by me while it was pouring out. Does anyone know what could be different with my truck that would cause it to slide so easily?
  3. Ridgeline
    22,616
    120,247
    Are you sliding just driving down the road, or braking?
  4. brandoo
    14
    8
    Nov 17, 2014
    Driving. It's very strange. I can barely hit 50 before my truck wants to jack knife in mist.
  5. Fajo
    Fajo The Dark Knight
    2,214
    2,352
    Jan 26, 2013
    Boise, ID
    How old is the rubber ? Seen this happen in cars before where the rubber got old and did not adhear to the road at all you would hit the breaks and the tires would would simply lock up. Replaced the tires and problem was solved. Kind of amazed me.
    Tho not sure this could happen in a simi with all the weight on them. Just a thought tho.
  6. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    Are your tires bald? Alignment out of wack?
  7. Dr_Fandango44
    Dr_Fandango44 Road Train Member
    1,053
    746
    Aug 27, 2012
    Austin, TX
    This can happen, especially if the trailer has no ABS. I hauled fuel for a local but large co and their trailers were so old they had no ABS and just a small amount of moisture on the roads would wreak havoc.
    Absolutely nothing I could do and the tractors were fairly new. Even at 30 mph I could feel the trailers sliding.
  8. STexan
    STexan Road Train Member
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    I can remember 25 or so years ago when driving a single axle tractor, getting some new tires and it was like that. Not sure if they were radials or bias ply. (radials were not the norm at the time)
    I think it was the brand of tire, and the fact they were new. I don't remember if we swapped them out or it improved as they got some wear.
  9. Mev
    Mev Road Train Member
    3,109
    1,102
    Jul 29, 2009
    Dont have your tandems put all the way forward.
    Thats one thing that will help
    88228822 Thanks this.
  10. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    Mold-release compounds usually linger for a number of miles & they are particularly slick when wet. Some compounds linger longer than others, but most should scrub off within 100 miles.
    If you get crazy with the tire shine it can do the same thing...
  11. brandoo
    14
    8
    Nov 17, 2014
    My tires are near new, at about 60%. My trailor is a 2004 and it does have ABS. My tandums are on the 9th hole from the front and my trailor is empty. Thank you everyone who has givin me their imput thus far. I appreciate all imput. Also one more thing I'm not sure if this would effect my sliding or not but I also have a fuel leak.
