Sliding tandems
Discussion in 'Questions From New Drivers' started by Uncle Charlie, Apr 17, 2007.
  1. Uncle Charlie
    Uncle Charlie Bobtail Member
    What do I do to redistribute the weight on my unit in the following situations:
    1-overweight on my steers.
    2-overweight on my drives.
    3-overweight on axles 4 or 5.
    Thanks for your help.
  3. heyns57
    heyns57 Road Train Member
    2,209
    1,011
    Dec 30, 2006
    near Kalamazoo Speedway
    1. Slide fifth wheel back.
    2. Slide trailer tandems forward.
    3. Slide trailer tandems back.
  4. Uncle Charlie
  5. notarps4me
    notarps4me Road Train Member
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    You forgot to tell him not to take on fuel!:biggrin_25523:
  6. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
    If you happen to have all three situations at the same time, then you redistribute the weight from your wallet to the DOT when you try to cross the scales.
  7. rangerman1
    rangerman1 Light Load Member
    80
    6
    Mar 27, 2007
    Cheney, Wa
    If you're talking all at ONCE, you're S.O.L my friend. Heynz57's got the right directions. Just remember that the weight increments are commonly 500lbs per hole on the 5thwheel slide, and 250lbs per hole on the tandems. (trailer) Maybe stating the obvious, but the weight will be re-distributed to the other axle.
  8. heyns57
    2,209
    1,011
    Dec 30, 2006
    Roofing is easy to carry from one end of the trailer to the other. Sliding cases of beer across the top of the load is a bit more difficult. Been there.....
  9. 25(2)+2
    18,750
    45,476
    Sep 18, 2006
    the road less travelled
    It may be that you reversed the 5th wheel with the tandem figures, the tandem can have 6 inch or 4 inch increments and the 5th wheel can also have different increments.
    AJ
  10. panhandlepat
    panhandlepat Road Train Member
    3,255
    2,243
    Jan 12, 2007
    on the tandems there are trailers with 250 pound holes (usually about 3 inches apart) and 500 pound holes (usually about 6 inches apart) you will have to look. from wht my trainer told me, most of the newer trailers are all 500 LB holes
  11. rockee
    rockee Road Train Member
    1,393
    673
    Apr 17, 2007
    Pacific Northwest
    From what I have seen on most trailers, is holes at four and six inches, typically a hole will relate to 300 - 400 lbs. Pat I think your trainer might have been misinformed (or maybe I am). Ive never heard of a "500 lb hole" before, unless your on the outskirts of LV
