Sling TV from Sling Media the new 500 Model
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by HardlyWorkingNeverHome, Oct 15, 2014.
  1. HardlyWorkingNeverHome
    HardlyWorkingNeverHome Heavy Load Member
    709
    316
    Mar 18, 2008
    Hamden,CT
    I just bought the sling box called sling TV, the new one with 500 listed in the model number. I have a newer Naxa TV that the TA sells with HDMI and a USB slot in the back. I bought a Google Chromecast and installed it to the back of the TV. The Chromecast is a pretty good product for transferring (casting) Sling TV from my IPad to the TV in the truck. It also works with Netflix but the reviews are horrible for the netflix App casting. I like the Chromecast for my use though.
    The Sling Box it self is hooked up at home to my U-Verse cable service. The cable service it self is very good but the internet upload speed is not fast enough. It is recommended that the upload speed at the house is at least 3 Megs per second. I'm switching to Comcast on Thursday which has 10 Megs upload and 100 download. The Uverse was only 1.8 on upload causing the sling box signal to buffer a lot in the truck. I also had to lower the viewing quality to lessen the pausing from buffering issues.
    The Sling Box can remote control the cable box from the iPad or iPhone while out on the road. It took a few calls to Sling Box support and AT&T to get the box to work through my fire wall so I could access it while traveling. Both were very helpful. Once you have set up the box in your home network and you know it is working the next trick is to get it to the truck. I use AT&T wireless. They currently have a huge Data promotion on 30gig plans and higher. You pay for 15 you get 30. Pay for 20 you get 40 and so on. With the download speed needing to be around 3 Meg's a second, AT&T's network is just fine.
    To Set up in the truck you need to download the sling TV App to the Cell phone or Tablet. You could do both but I prefer to have the App on my IPad mini. The screen is much bigger obviously, and I don't want to pay $14.99 twice to have this App on Both devices. By using the Hot Spot feature on my IPhone 5 you first have to set up and follow the messages on the TV to set up the Chromecast. Once that is set up, use the Utube App on your phone to verify that casting works to your TV. Once you know you are connected and it works you can just look on the TV and see your Hotspot name on the TV when the Chromecast is connected to the phone. Next you have to connect the IPad. When you see 2 devices connected to your phone you should be good to go. I open up the Sling TV App on the IPad connect, then click on live TV. I use this to watch all my DVR content so I don't have to stop driving to catch my favorite shows.
    The flaws
    1. Uses a lot of Data. 700 Megs an hour on lower quality setting. Over 1 gig per hour HD.
    2. Initial cost. $300 for the Box $35 for the Chromecast.
    3. Making sure you have 4g or LTE service when you park. No high speed cell data, no streaming TV.
    4. Must have one cable box at home that is rarely used. I use the one in my bedroom. No one uses it while I'm on the road. If someone changes the channel it changes in the truck as well!
    5. Chrome cast is not 100% reliable. Apple TV may be better, but for $35 I'll put up with the Chromecast.
    Advatages
    1. Watch your shows on your own schedule.
    2. No monthly fee like you would have with a dish other than the cable and Internet you already pay for at home.
    3. Can cut your Data usage by finding Free Wifi, or pay to use the Wifi at the truckstop. (Download should be over 3 Megs a second)
    Dieselboss, scottied67 and Gulf Thank this.
  3. snowwy
    snowwy Road Train Member
    20,539
    13,275
    Jul 6, 2009
    I've had sling for years, but don't use it. neat idea though. it was cheaper back then.
    worked just fine with 1.5 dsl. back in the day.
  4. Wolfyinc
    Wolfyinc Road Train Member
    2,888
    966
    Apr 21, 2013
    Salem, or
    I have a solution for that as well, called torrents, some use piratebay but I have several private sites I have been a member of and a seedbox which I download them to then download to my laptop when ready. I spend a bit extra for a decent seedbox which is running around $20 a month but I get all the movies and shows I want. I will use wifi when i can to get them off the seedbox but I do have unlimited data with my phone, it just throttles down the speed once I hit 5gb or so.
    HardlyWorkingNeverHome Thanks this.
  5. HardlyWorkingNeverHome
    709
    316
    Mar 18, 2008
    Hamden,CT
    there are some older versions still out. This one is the newest that works with HDMI and HD. I'm waiting to get Comcast at the house today to check out the quality difference. Now that I think about it I'm not sure it's possible to use truckstop wifi for this but I'm going to try.
  6. Wolfyinc
    2,888
    966
    Apr 21, 2013
    Salem, or
    it might not work too well, my experience with truck stop wifi is that its very slow but I have only used it a couple times since I didnt feel it was nearly worth the prices they charge and I only used points for it.
  7. snowwy
    20,539
    13,275
    Jul 6, 2009
    you wn't get anywhere with truckstop wifi.
    can you say 9.6 kbps dial up
    at night with everyone in bed, you might hit that 28.8 kbps dial up.
    i tried downloading my copilot gps app once. in the morning, i only had 100 megs, out of 1.5 gigs for the map. takes about 15 minutes with a real good 4g signal.
    X-Country Thanks this.
  8. Wolfyinc
    2,888
    966
    Apr 21, 2013
    Salem, or
    never experienced that slow but like I said only used it a couple times, the last time was at a TA I used my points for and the speed was 1.5mb or so, my phone gets much higher than that, right this second my phone is hitting 19.4mbps and if I park in certain places nearby I have reached over 30.
  9. X-Country
    X-Country Medium Load Member
    645
    462
    Mar 27, 2014
    use foxfi to tether your devices to internet.
    when maximumsignal.net finally has their 4g/lte signal boost amps for sale, you can order one or get one from wilson amplifiers...they boost cell phone service/data signal to full signal almost anywhere you are or go.
    forget using wifi at truck stops...thats a pipe dream. speeds are dialup speed...awful. slow. not near enough to stream continuously.
  10. snowwy
    20,539
    13,275
    Jul 6, 2009
    last time i installed foxfi on my sprint phone. it said not subscribed. had to look for a different app to use.
    if it requires a paid subscription now, then why even both with the store. both my phones have stock apps that also require subscription. might just as well use those.
  11. X-Country
    645
    462
    Mar 27, 2014
    it wont work on certain sprint phones.
