Slipper clutch
Discussion in 'Trucks [ Eighteen Wheelers ]' started by DDS, Oct 28, 2009.
  1. DDS
    DDS Medium Load Member
    519
    177
    May 20, 2008
    Toronto
    Has anyone here ever used a slipper clutch for drag racing. I ask because I have talk to a few companys and they do not think it is possible to shift gears. They sell pedal and glide clutches used for pulling in one gear. They do not think you could get a shift made do to the force on the plate is made by rpm and you may not be able to press the clutch in. Even if you used air assist, it may just break the arms in the plate.
  3. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    I couldn't see how you could. All the guys I know that run them for sled pulling can barely hold the pedal down long enough to spool the chargers, even with hydraulics. I don't think shifting would be an option.
    DDS Thanks this.
  4. DDS
    519
    177
    May 20, 2008
    Toronto
    The lipe I use is also hard to hold and ride off the line with the 5900 lb plate but the slipper makes even more pressure with rpm, so I think using is out of the question unless I want to swap out clutches between my drags and dirt pulls.
  5. Bent Wrench
    Bent Wrench Medium Load Member
    588
    205
    Aug 11, 2009
    Cornholio, OR
    Pull/push on shifter and activate ignition interrupt.
    Be sure to have your head back against the pads before triggering interrupt?
    Use an automatic.....
  6. DDS
    519
    177
    May 20, 2008
    Toronto
    lol.....have had guys try auto, will not stand up to torque. I know of one truck the had four heavy duty transmissions built in a row, the truck would lanch great but burn the clutches on the first shift, the trans company gave up.
  7. bern009
    bern009 Light Load Member
    136
    14
    Oct 4, 2009
    gr_nt. truck ? do you did is engine?
  8. DDS
    519
    177
    May 20, 2008
    Toronto
    I have not touched it but may have been involved..................... he does not know it though.
  9. Bent Wrench
    588
    205
    Aug 11, 2009
    Cornholio, OR
    I don't understand, you are able to overpower a clutch, but don't have enough power to start out in the gear you will pull in?
  10. underpsi
    underpsi Road Train Member
    1,266
    292
    Sep 18, 2008
    Toronto, Ont
    No he wants a good clutch for pulling as well as drag racing:yes2557:
  11. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    From all the stuff I have researched your pretty much gonna have to swap clutched in between events if you want the best for each. All of the pullers I know diesel tractors and semi trucks)have slipper clutches and there is no way a person would be able to shift them while in the higher RPMs. I've used a slipper clutch in a freinds pulling tractor and Jfaulk99 is right...I could barely keep it held down to sppol the turbo. The clutch pretty much pushed the pedal out as the RPMs increased which is what the slipper is intended to do. I haven't run a Lipe yet, but am planning on installing on over my Christmas/New Years break.
    As for autos...I've only seen one or two super semi trucks running them on a consistant basis and survive the abuse they get with the high torque and loads. I don't know how much they cost to build and maintain, but I imagine it is pretty high since no one else has done it. I really don't see how a auto would be able to survive the loaded truck race. I think it would be able to survive in the bobtail race and sled pull where the abuse isn't as bad.
