Slow lift axle
Discussion in 'Trucks [ Eighteen Wheelers ]' started by tbone1471, Oct 8, 2012.
  1. tbone1471
    tbone1471 Bobtail Member
    25
    Apr 1, 2012
    I have a tri-axle dump tuck and the lift axle is slow to move. I put a new cab switch in and both quick releases. The regulator is set to 60 psi. The reason I replaced these parts was because when I would flip the switch it would be slow to come up. Now it seems I screwed myself. I was thinking it is possible that I got a bad switch because when I am driving down the road I can hear air pulsating out of the exhaust of the switch that matches bumps in the road.
    Any ideas?
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,729
    Jan 30, 2010
    keep stroking.
    is it mech switch or elec silinoid switch?
  4. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    Reinstall your old switch for testing purposes. Do your new Q-R valves have the same crack pressure as your original valves?
  5. earthmover
    earthmover Medium Load Member
    563
    20
    Jan 27, 2009
    castalia , north carolina
    why do you have it set at 60psi???? if i go over 30psi it will try and pick the front wheels up off the ground... and if i get in the rain at that psi i just slide in he when trying to turn.. i set my drop axle at 20 and rides like a dream...if the axle still go up and down slow check your lines from bends that will do it as well....i have a freightliner tri axle dump myself....hope this helps...mike
  6. Superhauler
    12,209
    100,729
    Jan 30, 2010
    keep stroking.
    another thing to check there should be a regulator on the main supply line from the air tank not supplying enough air to it. ie from dirt in the line or being faulty. had that happen a few times.
  7. bender
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    Since this happens when he's hitting bumps I can't help but think the axle is bouncing and causing the Q-R valve to release air due to a lower crack pressure rating on the new valves.
  8. Superhauler
    12,209
    100,729
    Jan 30, 2010
    keep stroking.
    missed that statement. yep could of got the wrong crack pressure q/r valves.
  9. earthmover
    563
    20
    Jan 27, 2009
    i still think its to much psi .. if i cross a track or a speed bump my drop axle will push out air so that its not to much and burst a bag.. try to lower the psi to bout 20/25 and drive it and i beat the axle will raise and lower faster...nobody that i know and work with has that much psi in the drop axle ...
    also with that much psi it may just be keeping the q/r valve open all the time.. my valve went bad on my truck early this year and the axle would not come up at all.. put and new valve on problem solved, as stated the valve is only good to so much psi or it will release...
  10. tbone1471
    25
    Apr 1, 2012
    The switch is mechanical.
    The quick releases should have the same pressure ratings as the old ones. But I am not sure... I took them to the store and I am assuming they gave me the right ones. Any ideas what pressure I should be running?
    I am going to install the old switch and see how it works with that. Perhaps I got a bad switch.
    I guess I will put a new regulator on it... I had someone flip the switch and I watch the gauge and it will go right to the set psi but the axle will still move slow.
    As for pressure I have tried pressures of 20-90psi and it does it at all pressures. If the pressure is lower the axle is slower and vice versa. I don't have a problem running at 50-60psi there is no difference in handling. It is on an air ride Peterbilt. I run them this high just in-case I get stopped at the scales. Looking at Hendrickson's chart I need about that much psi to make sure my axle weights are correct.
    Thinking back when I had the original problem I would flip the switch and the quick release would not activate. The air would bleed out of the switch exhaust to raise the axle...
  11. Superhauler
    12,209
    100,729
    Jan 30, 2010
    keep stroking.
    i dont know if it's to much pressure or not. i run 10 lbs more in my pusher than what my sus gauge shows and that makes the pusher carry the same weight as my other axles. but thats a different setup than what you'all have with dumps.
