Slow seting emergency brakes
Discussion in 'Volvo Forum' started by USFT, Jan 5, 2013.
  1. USFT
    USFT Bobtail Member
    9
    Dec 15, 2012
    this problem i am having is on a dryvan trailer, trailer releases, drives and brakes fine, but when i set the emergency brake air starts to come back out the gladhand (being pushed back towards truck) and it takes a good 5 min before the emergency brakes are aplied, took down the valves and cleaned realy good. still the same problem, any ideas
  3. Driver of the year
    Driver of the year Medium Load Member
    442
    249
    Sep 28, 2012
    Tampa FL
  4. cuzzin it
    cuzzin it Road Train Member
    3,639
    11,468
    Jan 19, 2008
    Berea, KY
    Water in the air tanks. turn the petcock to open on the air tanks
  5. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    Back feed the system with air and isopropyl and see if it helps?
  6. USFT
    USFT Bobtail Member
    9
    Dec 15, 2012
    No water in tank,already checked
  7. dude6710
    2,162
    622
    Mar 26, 2010
    MN
    Ok then add isopropanol to the trailer tank.
  8. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Its not broken....Some trailers (rare) are set to discharge the air suspension when you apply the brake (thus loosing all their air). Most of arnt like that any more since then u need to air them back up. Most likly the parking brake sets instantly but it take a few min to loose all its air from tanks and suspension. The idea was to make the trailer more stable while loading or in heavy winds by dumping the suspension and letting the trailer rest on a hard surface. If you pull the gland hand it will drain through there as well.
  9. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    did you do a tug test to verify the brakes were NOT set? Im guessing they are set and ur just still hearing air hiss from the tanks and suspension. If they truly arnt set, then its a different problem then I had on an old trailer.
  10. Nextlvl
    Nextlvl Bobtail Member
    17
    Jan 5, 2013
    I had a drop deck that did the same thing. We replaced the distribution valve on the front of the trailer air tank, and it fixed the problem on my trailer. Just a thought...
    CondoCruiser Thanks this.
  11. USFT
    USFT Bobtail Member
    9
    Dec 15, 2012
    That problem started last week it was fine before, and brakes are not set bcz trailer is still rolling, this is an older trailer, new chambers and airlines, i'm thinking the valve where the abs is mounted on might be bad
