Small antifreeze leak at water pump
Discussion in 'Experienced Truckers' Advice' started by GPAryan, Jul 17, 2017.
You do carry extra coolant with you and check the level regularly, correct? -
The bigger question is what is the cost to tow and replace an engine vs fixing a water pump gasket leak?
If it's a newer truck, it should tell you when the reservoir level goes low. Don't ever disregard this particularly in the middle of summer. -
When your truck starts talking to you, it's a good idea to listen.
Mine had a leak cold leak was losing all the coolant over night...
Fix it now or later little bit now lot more later
Are you broke and don't know it fixed the problem
Itll only leak till it gets below water pump level...
Wow.
Just get it fixed, nothing like getting pulled into a scale, getting a level one and then be told "oh you have a leak, can't move it, get it fixed or towed to get it fixed ... please sign here."Grubby Thanks this.
