Small compact printer needed
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Hegemeister, Mar 9, 2017.
  1. Hegemeister
    Hegemeister Road Train Member
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    Looking for an inexpensive printer to keep on the truck. Quality not important. Simple b&w test documents. Need the smallest size for storage.
    Any input would be really appreciated. Thanks!
  3. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    Do you have an inverter? If so what size? The truly compact "portable printers" are kind of costly to purchase and to use but have minimal power requirements.
    I'm not a fan of inkjets, varying temperature extremes and no regular use can render cartridges bad in no time.
    I run a very small HP laserjet on my 1500 watt inverter.
    http://www.pcmag.com/article2/0,2817,2389136,00.asp
    Hegemeister Thanks this.
  4. Hegemeister
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    Plenty of AC power. Good point regarding the inkjets. I didn't think of that.
    What is the model of the laserjet you are using? Thanks.
  5. STexan
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
  6. flood
    flood Road Train Member
    4,161
    4,031
    Dec 25, 2010
  7. loudtom
    loudtom Road Train Member
    1,717
    2,801
    Aug 26, 2016
  8. Hegemeister
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    Thanks all!!!
    Does anyone have a problem with the ink cartridge with it being exposed to extreme temperatures in the truck?
  9. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    Not only will varying temps cause issues with ink cartridges, it will eventually cause issues with the print head clogging. Buy cheap. If you keep your eyes open, you can sometimes get a printer for $30. Which is cheaper than buying replacement cartridges. Pitch it when you start having issues.
    Just don't toss it out like a wizz bomb. Actually saw one behind the curb at a truck stop in Virginia not long ago.
  10. Hegemeister
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    You know what would be perfect? A very small B&W laser printer. I would think the laser powder has more environmental tolerance. Just want to print permits, ID cards, etc. nothing fancy.
  11. flood
    4,161
    4,031
    Dec 25, 2010
    I've had the same printer in the truck for 5 years and never had a problem with it...
    PORTABLE printers are made to take abuse that CHEAP desktop printers can't.
    As to temperature extremes really how often do you let the temperature in your cab get above 85 or below 35....??
    BTW until we went to elogs we were using a laptop log program so we had to print our logs every day for 3 years and never had a problem with this printer. When we used CHEAP printers we would go thru 1 a year... buy CHEAP and you get what you pay for
