O.K.,Its time I asked this question. I am wondering WHY OTR companies would use small fuel tanks on their trucks,? I,myself,find this terribly annoying,and do not understand this,especially a flatbed company,where most trailers are spread axle and have more of a cushion with regards to weight distribution on the trailer,-do not have to worry so much about the drives?![]()
Small Fuel Tanks
Discussion in 'Experienced Truckers' Advice' started by Bumpy, Mar 29, 2011.
Page 1 of 8
Its for total weight not just how much is on the steer or drives.
TheHealthyDriver, heyns57 and The Challenger Thank this. -
OK then,I just think it would be a lot more convenient to pick up a load on half tanks,and knowing for sure the load was light,fill up the 150gl tanks,and NOT have to worry about fueling for awhile.?
vs.,havin fuel tanks with a 500 mi range,and sometimes then having the HORROR of having to get fuel twice a day?
Spring time LOAD RESTRICTIONS limit some trucks off certain roads , small tanks are a benefit this time of year.
i would rather have the option of having big tanks and running them 1/2 full or less if i had to--guess it would also depend on where the tanks are mounted--i kinda prefer forward mouted tanks--then i have no problem maxing out my steering if i want with fuel not having to mess with 5th wheel--only trailer tandems
Raiderfanatic and TheHealthyDriver Thank this. -
I have to agree--without knowing the specifics--IMHO--an m/t 100 gallon tank--is not significantly lighter than an m/t 150 gallon tank--so in weight situations you just take on LESS fuel with larger tank--but at least have the option when weight isn't an issue--100 more gallons--takes you a whole lot farther--and in today's brave new world--with cvsa2010--and limited work times--who wants to fuel anymore than they have to?
Just my $.02 -
My carrier (on the reefer side) did it purely for gross weight savings.
The problem is, how many drivers think about putting on less fuel? Not many want to put up with that headache. With fuel weighing around 8lbs per gallon if memory servs me correct, 100 gallons would be 800lbs. Big difference.
Or how many are/aren't smart enough to figure out how much to put on?Hammer166, lilillill and Raiderfanatic Thank this.
I guess you are being serous--so I guess I will be too--knowing how much fuel you can put on is part of the job--same as anything else--and more often than not if I had 100 gallon tanks--I couldn't fill them--so there ya have it!
just my $.02
Page 1 of 8
