Small problem..well maybe a Large problem.
Discussion in 'Questions From New Drivers' started by Gently, Feb 8, 2018.
  1. TripleSix
    134,917
    It was a perfect demonstration of lane control by the both of you, you and the wide load. It’s a small part of the ‘science’ that @Hammer166 and @Lepton1 try to teach. You go left to pass, you don’t “drift”, you plant your left on the yellow fog BEFORE getting to the side load. He goes right and does the same. The veteran thing was that even tho the wall was coming up, you and he maintain the same spots in your lanes. You made it look easy...after all, it’s just driving, right?
    EDIT: And the icing on the cake, wide load showed his appreciation for your driving boy flashing the headlights.
    Lepton1, scottied67 and Justrucking2 Thank this.
  3. Gently
    Gently Bobtail Member
    10
    12
    Feb 8, 2018
    I currently live in west Virginia but I can move any where. I really like the otr and would like to stay in that branch.
  4. Plantfoam
    Plantfoam Medium Load Member
    393
    1,129
    Aug 18, 2015
    DFW
    One time I overcorrected so much I ended up in lava. I just told the company that someone hit my truck when I was in the shower.
    Chinatown Thanks this.
  5. Cattleman84
    Cattleman84 Road Train Member
    10,057
    71,985
    Nov 1, 2017
    The Sticks, Idaho
    @Gently
    I feel for you driver, however... A very important concept to learn from this is to try and anticipate how that wind is going to hit you and be ready to react in a controlled manner to compensate for said wind. Wind in WY can be devastating at times, but is also a place that one can learn to "read the wind" by watching the lay of the terrain around you as you drive and take mental note of how you feel the push of the wind change based on the lay of the land...
    Ex: I'm driving along and can feel the wind pushing me to the left (which I am compensating for with slight right steer). Ahead on the right is a large hill close to the road, as I come along side this hill the wind push becomes less or maybe disappears completely. Further ahead I see open flat terrain on both sides, followed shortly by another large hill that the road way is cut into ( hill on both sides). As I see this I start to think "the wind is most likely still going to push me to the left, but not guaranteed. And because the hill I'm beside and the hill beyond the open terrain cause a funnel the wind very likely could push with more forse than before." So now I'm coming away from the first hill into the open terrain, but I'm already prepared for the likelyhood of a very hard blast of wind, both hands on wheel, I may even slow down some. As soon as I detect that wind forse and direction I begin to compensate with easy controlled steering which ever way is needed.
    The same concept applies when passing, as the vehicle you are passing will block most of the wind, and when you break through the wind coming around the other vehicles hood it will very likely be more wind forse than what it was while following or approaching behind said vehicle. Especially if you have come into a wind tunnel type terrain during the pass.
    This can be a hard lesson for some to learn, and WY is not a forgiving teacher, but can be a very good one if you pay very close attention and learn quickly.
    I hope this doesn't come across as me picking on you or belittling. I only hope you can take you bad experience and maybe some info you have gathered hear from other drivers and learn from it.
    All in all of say you faired well, seeing as you are alive and both trucks stayed shiny side up. Best of luck in the future
    Truckermania, Lepton1 and Gently Thank this.
  6. magoo68
    magoo68 Road Train Member
    3,393
    5,386
    Jun 11, 2011
    st malo mb canada
    Anyone else feel the first lead had a attitude for a reason and the second lead was not the same caliber of trainer... A piece of advice I got 25 years ago as a rookie might apply here ( learn to drive before you learn how to go fast )
  7. Gently
    10
    12
    Feb 8, 2018
    Well the first lead had this idea that the school taught us everything so he just kinda said "SUCKS to be you" and goes back to his phone videos and nasty music. I found out later he has never completed anyone for all 4 weeks.
    Lepton1 and magoo68 Thank this.
  8. BrandonCDLdriver
    BrandonCDLdriver Road Train Member
    1,191
    1,462
    Sep 1, 2017
    You made your student pass an oversized load as their first pass? WTF?? LOL
  9. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    Fog lines are your friend. ;-)
    Lepton1 and TripleSix Thank this.
  10. Justrucking2
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    Some of these so called trainers shouldn't be training dogs, much less drivers. I have seen a few, and was a rookie once too. But, I had been driving since I was old enough to get my feet on the pedals, farm equipment and trucks, none had power steering and a grandfather that was not afraid to jump your rear end when you screwed up. ;-)
    Good luck!
    Lepton1 and buddyd157 Thank this.
  11. Toomanybikes
    Toomanybikes Road Train Member
    2,644
    3,915
    Apr 8, 2009
    You may work again. I defiantly could happen. But, the bad news is sideswiping anything is one of the 5 deadly sins in trucking.
    I highly doubt you will get on with a training company again. I think even second chance Swift will turn you down due to the nature of the accident.
    You will have to look into companies that don't use the DAC. Some of the less desirable companies might over look this situation, but even then it is going to be tough.
    TripleSix and buddyd157 Thank this.
