Smaller Company or Company with Better Equipment
Discussion in 'Questions From New Drivers' started by MysticTrucker, Mar 18, 2013.
  1. MysticTrucker
    MysticTrucker Light Load Member
    129
    49
    Jan 23, 2013
    Cottage Grove, MN
    I have an opportunity to go on with a smaller company of 300 trucks (Halvor Lines, no APUs, no inverters) or a larger company of 1,000 trucks (Melton, +APUs, +inverters). As a general rule, which is the preferred path: smaller companies with less "bells and whistles" or large companies where equipment may have more "creature comforts"?
    Thanks!
  3. Njnoob
    Njnoob Light Load Member
    111
    40
    Oct 26, 2012
    Northcentral NJ
    I think if you have the opportunity to go with a small company? I'd do that, if they have a good reputation...
  4. P5CU
    P5CU Bobtail Member
    4
    Mar 18, 2013
  5. Emulsified
    Emulsified Road Train Member
    3,663
    3,499
    May 6, 2010
    Dallas, TX
    I'll take a different tack on this one.
    I'd go with a company that runs 2010 or older trucks at the moment.
    Since moving inside operations, I've come to realize the incredible amount of downtime with the 2011 engines and newer. There are a lot of bugs still out there and it translates to downtime for the drivers and company.
    Yes, the company may be footing the bill, but you, the driver are still sitting there waiting for Cummins to get that engine fixed. It's virtually always related to the DEF. Sensors, filters, etc.
    I was speaking with our service department about this (thought it was my imagination) and they confirmed the downtime with the newer engines is more than six time greater than the older ones. The highest failure rate is between 225,000 and 350,000 miles.
    They'll get this fixed eventually, but in the meantime, I'd look for a place where I can have a truck that's a bit older.
    Think of it this way. If you're running an average of 400 miles per day (2800 per week) and you're down 15 extra days per year (that's VERY conservative, according to the Cummins rep), it translates to 6,000 miles per year. If you're at the lower end of the pay scale...0.30/m, that comes to $1,800. If you're at 0.40, it comes to $2,400!
    Maybe a shiney new truck is worth that to you, but when I was driving, I was doing it to make money!
  6. MysticTrucker
    129
    49
    Jan 23, 2013
    Cottage Grove, MN
    Thanks Emulsified, I appreciate the info. The companies are both running T660's, the question was more about one company is smaller without APUs or Inverters, while the larger company is larger and has APUs and Inverters. Same trucks.
  7. Emulsified
    3,663
    3,499
    May 6, 2010
    Dallas, TX
    you can buy a plug in inverter that will run your laptop or small items. If you don't have an APU, you can idle.
    If you take the fiberglass and doors of the rig, they're much the same....frame, engine, tranny.
    I'm speaking of fleet trucks. Some have preferences like a more narrow cab in a 660 or W-900, but they have the same engines, trannys, etc.
    Some companies will allow you to install an inverter up to 1500 watts. They may require the installation to be done by their shop (sometimes at a nominal fee). Just ask.
    These are areas that smaller companies will often negotiate.
    MysticTrucker Thanks this.
  8. joseph1135
    joseph1135 Papa Murphy
    11,340
    27,299
    Nov 8, 2009
    The Highway To Hell.
    I work for a company that has new trucks, APU units and inverters and they aren't all that big but certainly not small. I love having the APU and BY THE WAY!!!! Lol. I have a 2012 KW t700. In almost 200,000 miles, I've not had an actual breakdown yet! Its a good truck. Be safe out there
  9. MysticTrucker
    129
    49
    Jan 23, 2013
    Cottage Grove, MN
  10. joseph1135
    11,340
    27,299
    Nov 8, 2009
    I work for Lessors Inc out of Eagan,MN. Not a bad company at all bit seeing as you're new they aren't a option for you.
  11. MysticTrucker
    129
    49
    Jan 23, 2013
    Cottage Grove, MN
    I was looking at Transport America in Eagan as well. I live not too far from there. I am very wary of the huge companies (we all know who they are) in favor of smaller companies. I really like the Halvor Lines operation out of Superior, WI. I've known some folks who have driven for them and the director of the CDL program here at the college knows them and recommends them as well. Smaller fleet, 300 or so tractors and they run flats which is what I intend to do.
