FACT - Volvo D13 Trucks - @ 500K need new CAMS - they ware down i have seen
this many times now and i see that this is a issue.
After replacing my Cam and Rocker arm assembly my trucks runs like NEW.
BUY IT BEFORE YOU NEED IT - ALSO GET REFURBISHED ROCKER ARM ASSEMBLY
This will save you a Head Ache when Volvo tells you it will cost 10K to fix this issue.
CAM - 1000 to 2000 and 300 to 1000+ for Rocker Arm assemble.
WHEN YOU BUY WITH TIME
Smart - Volvo Trucks @ 500K - need CAM
Discussion in 'Volvo Forum' started by JerryD13, Aug 13, 2017.
Have 800,000 miles on a 2011 d13. Cams and rocker arms are fine. Have regular oil samples taken and analyzed. Maybe do that Instead. Then when you need it done get it done.KB3MMX Thanks this. -
Many over 1M Mike's never touch cams or rockers.
It is not a "FACT" per se if it's not a 100% accurate , factual statement.
Maintenance , maintenance, maintenance.. Choose your oils and filters wisely, they can definitely effect your wear parts lifespan but is not a 100% guarantee in everything.JerryD13 Thanks this.
