So i got some water in the engine last night.....
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Powell-Peralta, May 19, 2011.
  1. Powell-Peralta
    Powell-Peralta Road Train Member
    1,585
    240
    Jul 17, 2007
    There is/was some flash flooding around here lately and i drove into a massive puddle and i think some water got into the engine.
    Immediately afterwards i lost power and the engine would not rev past 1100. So, i pulled over. The engine ran rough for a few minutes, but after a few minutes i was able to get it to rev someone normally. i then proceeded but sometimes did not have lots of power---it seemed like the turbo would cut in and out unpredictably. After maybe 10 miles or so everything seems back to normal.
    What would cause this?
  3. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    sounds more like you got some electrical connections wet, and then they dried. In order to get water "in" the engine it would have to be deep enough to get into the air intake, and that wouldn't be a puddle, it would be a pond or a lake!
    Did you happen to notice any changes in voltage if you have a volt meter? You could have had a major short in the starter area to reduce voltage drastically and that would effect the engine, and then dried.
    Roadmedic Thanks this.
  4. Powell-Peralta
    1,585
    240
    Jul 17, 2007
    That seems more plausible. i do have a voltmeter, but i did not pay attention to it(didn't think electrics had anything to do with the problem). But the oil pressure and temp seemed normal so i felt it was safe to let it idle and then try to drive away although it did seem risky as well.
  5. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    my money would also be on electrics. maybe engine position sensor connection, or ECM connections
  6. outerspacehillbilly
    outerspacehillbilly "Instigator of the Legend"
    4,349
    2,430
    May 28, 2009
    The Who's Your State
    I think you got water in between your ears.
    Ken and Joetro Thank this.
  7. Big Don
    Big Don "Old Fart"
    17,996
    35,644
    Sep 8, 2007
    Utah's DIXIE!
    Just a bit of advice her P. P. USE A BOTTLE! That way you won't get the wires wet.:biggrin_25513:
    :biggrin_25523:
    :biggrin_2559:
  8. FLATBED
    FLATBED Road Train Member
    FREIGHTSHAKERS always had wiring harness problems , bit of water on the motor ( not in the motor ) and runs rough.
  9. outerspacehillbilly
    4,349
    2,430
    May 28, 2009
    Not only are his wires wet they, are crossed and had a full system meltdown! :biggrin_25525:
