So who's at fault when hitting power lines sagging to low?
Discussion in 'Ask An Owner Operator' started by 86scotty, May 12, 2025.
  1. 86scotty
    86scotty Road Train Member
    4,643
    12,664
    Aug 27, 2017
    Appalachia
    I'm driving down to two lane highway the other day on a route I run pretty often. Power lines cross this road all over the place just like they do everywhere else.
    I heard a helluva noise and immediately knew I had hit a power line. I look in my rearview mirror and there's lines flying and poles swaying everywhere.
    There is no traffic in front of or behind me so I slowed down to make sure no lines landed on the road and no poles came down.
    I kept rolling. I picked up the phone to call it in and then I thought better of it. Trucks run this road all the time. I wasn't sure if they would blame me so I decided to let the next guy call it in. I stopped about five minutes later and there was no damage to my truck or trailer.
    What would you do? Could I be cited for this?
    It's a public highway with no height restriction. Don't they have a responsibility to keep the lines above 13'6"?
  3. drh72
    drh72 Light Load Member
    175
    301
    Aug 19, 2012
    Northeast Minnesota
    If you are of legal height, then no you cannot be cited. Actually, if you damaged your equipment or were injured you would have a case against the power company.
  4. flood
    flood Road Train Member
    4,168
    4,045
    Dec 25, 2010
    Yes they are required to be above 14'
  5. Grumppy
    3,175
    11,084
    Dec 11, 2010
    West Monroe, La
    I agree. As long as you were not above any legal height for that road then you are not at fault. Power company is required to maintain power lines above 13' 6".
    I don't know what the legal required height is but it must be at least 13" 6'.... that I do know.
    EDIT:
    "The minimum height for power lines over a roadway depends on the voltage of the lines and the presence of truck traffic. For lines carrying up to 120-240 volts over driveways, parking lots, and alleyways, the minimum height is 16 feet. For roadways and streets with commercial traffic, the minimum height is 15.5 feet."
  6. Rugerfan
    Rugerfan Road Train Member
    7,624
    38,635
    May 3, 2011
    Redding,CA
    I mean I’d call it in just to keep things on the up and up. These days you never know who has a camera setup somewhere. Being at legal height and being the fault of the power company why not call in?
  7. AModelCat
    161,606
    Isn't that technically considered leaving the scene?
  8. Espressolane
    18,264
    113,690
    Had something similar happen when I was delivering to a new housing development. Was not power lines, was phone and catv lines. Didn’t know it even happened. Only found out when a phone company truck came to a screeching stop where the unloading was going on. Guess it was pretty easy to follow all the downed lines to the truck. Long story short, the lines were measured across the road, they were under 13.6. Not my problem. Needless to say, they were not very happy about it.
  9. 86scotty
    4,643
    12,664
    Aug 27, 2017
    Appalachia
    This could've been phone and cable, I really have no idea.
  10. Big Road Skateboard
    6,721
    37,832
    May 2, 2021
    I hit a cable line on a county road that I'm on often. I wasn't over height, and yes, they are responsible.
    The cable company had worked on the line I hit two days prior.
    It broke two electric poles it was attached to, the wire came down in front of me, and blew the transformer to hell.
    I called the sheriffs dept and electric company, nobody attempted to blame me
  11. Allow Me.
    10,732
    12,448
    May 28, 2009
    Rancho Mirage, Ca.
    The power co could have been doing some maintenence and didn't quite cinch up the line tight enough to keep minimum clearance across the highway.
