So, you're wanting to run local...
Discussion in 'Experienced Truckers' Advice' started by ColoradoGreen, Jul 5, 2014.
  1. ColoradoGreen
    ColoradoGreen Heavy Load Member
    755
    879
    Mar 1, 2010
    There seems to be a general feeling on this forum that once you've gotten to the point where you can run locally that you've gotten yourself into a much better position. No longer biding your time at the mega-fleet OTR companies, you'll be home more, see wife, husband, kids, dog, carpet and La-Z-Boy much more often. Sounds great, doesn't it?
    In a lot of ways it is. Having started driving younger than most, my first times driving were local, I couldn't leave the state. The company I worked with was local, mostly, as well, the longest runs would be considered more "regional". After that, I did run some OTR hauling milk. I enjoyed it in a lot of ways, always liked getting a load headed somewhere I hadn't been before.
    And, now I'm back to local, and loving being local again. But, I thought I'd shed some light on what it's like running local for those who have their eyes set on getting themselves to where they're home (most) nights (or days, depending on your schedule).
    There's a lot of conversation on the forums about the physicality of different sides of trucking. A recurring question among many of the student-drivers is whether or not flatbed work would be a good fit for them... Heavy lifting, strapping, chaining, tarping, climbing up and down loads. Well, generally speaking, if you're going to run local, your driving job is going to become a lot more physical.
    I'll give you an example. I primarily pull a lowboy now hauling machinery, oversize and overweight. It's what I learned to drive around and where my driving started. Aside from machinery, I'll also haul general construction goods, from pipe to trench boxes, to excavator buckets, about anything the customer asks us to put on the trailer.
    There's one particular customer, a good customer, who always has a bunch of oddball or complicated things needing to move from jobsite to jobsite. One particular day involved a small sheepsfoot compactor, two trench boxes with spreader bars, two excavator buckets, and a compaction wheel for an excavator. All of this stuff was at two separate jobsites and another excavator bucket needed to be taken from one to the other. I arrived at the first jobsite and we loaded the sheepsfoot compactor, the first trench-box and spreader bars, and the excavator bucket that needed to be shuttled to the other site. 8 chains and 3-straps, not too bad, and the morning was still cool.
    Made it over to the next job-site, unchained the bucket and unloaded it. Also unchained the spreader bars, took them off, and unchained the trench-boxes to stack the second set of trench boxes and spreader bars back on top. Re-chained the two trench boxes, and the 8-spreader bars, meanwhile, had them loading the other excavator buckets and comp wheel.
    Plenty of climbing up and over the loads. I typically keep an eye on the guys loading my truck unless it's one of the customers I trust and know the operators. The spreader bars, which are essentially a 10-inch diameter steel pipe and weigh in about 100-lbs a foot, had to be hand-rolled off the forks for loading to make sure they didn't come rolling off the top of the trench boxes. Then, as many know, the climbing when you're setting your straps, especially anything belly-wrapped.
    By the time it was all said and done, there were 17 different straps and chains on the truck, and doing the math, since we had to unchain to load more pieces on, that's 28 different chaining and strapping procedures to get the whole load settled on the rig. Meanwhile, it's the middle of the day and up around 95-degrees. That was on the heels of a machine in the morning, simple enough, 4-chains and a strap, so, 33 separate times tying down a chain or strap in a day.
    Typically I'm doing loads like this 2-3 times a week. As an O/O, I don't mind it a bit, it's good money, takes long enough to chain and strap all the stuff down I shut the truck off and bill hours while the truck isn't costing me anything to just sit there while I sweat my ### off.
    But, that doesn't inherently mean the days where you're just moving machinery or single-piece loads are any less strenuous. Even easy, 4-chains-and-gone machines, 2 or 3 a day can turn into a fair amount of work. I remember doing the de-railed rail-cars, we'd typically squeeze in at least 2, maybe 3 loads a day shuttling them in for recycling. 6-8 chains per car depending on just how damaged it was, but, halfway through the second car in 100-degree heat in dirt and coal dust and you were sweating.
    Now, don't take this as me complaining. I love working local, and the chaining and strapping is a good work-out, even if you're totally wore out at the end of the day.
    But, let's take a look at a couple other different types of local trucking:
    That guy in the daycab pulling the reefer? You might have heard some of the veteran produce and meat-haulers use a phrase called "hand-bombing" or "finger-printing" a load... what's finger-printing or hand-bombing a load? It refers to hand loading and unloading the reefer. And for some guys pulling the reefers locally, still delivering to ma-and-pa shops, hand-bombing is still a daily thing. Even if every box is only 20lbs, which, I really doubt they're always gonna be light, by the 100th box, you're gonna' be beat all to hell...
    So, what about that daycab dragging the tanker?
    Well, aside from getting to work around stuff that explodes, imagine dragging hundreds of pounds of hoses around multiple times a day making deliveries to gas-stations...
    Garbage trucks, you're lifting thousands of pounds worth of garbage from trash-cans every day...
    Dump trucks... climb up on top of that load with your shovel and starting pushing it into the corners so you can pack on as much as you can...
    Concrete trucks? Get ready to be jumping in and out doing wash-outs at job-sites, and also periodically getting to climb into the barrel and clean out the mixer body itself... yes, there's going to be concrete stuck on the inside that needs to come out...
    So, what am I getting at here? Does this mean you should be sticking to the longer distance stuff? Not necessarily.
    Like I said, I love running locally. There IS something to be said for sleeping in your own bed (most) nights, and there IS definitely something to be said for seeing family more often.
    But, what I am getting at is, don't think it's all roses and cinnamon buns when you're running local. I've pulled stepdeck OTR, and the chaining and strapping you'll do can be a work-out, but, once you're all tightened down, other than a couple checks on the way, you can go 1, 2, 3 days, maybe even a week before you're pulling them off and chaining down your next load.
    I'd have a hard time being convinced to go back to OTR again... but, I thought I'd give some of the newer drivers on the forum who are dreaming of running local a look into what it can be like physically...
    You might have also noticed I kept saying you'll sleep in your own bed (most) nights. Well, there's always going to be oddball runs that have you out for a night, and there certainly can be days you're so tired, that, if you have a sleeper like my truck (small sleeper), you're going to crash, at least for a few hours, in your truck rather than driving home.
    And don't forget traffic. Remember how it's really, really annoying when you hit a city after cruising out on the open highways and you're suddenly dealing with loads and loads of traffic again and lots of idiot drivers?
    That's all day if you're running local. There's a fun part to running local at night if you're willing to turn your sleep schedule on end.
    Again, this isn't me complaining. I love it, I love being local.
    However, be prepared if you're going to go local, in virtually any sector of trucking, that the physicality of the job can increase dramatically.
    Ke6gwf, RookieJ1987, Mr Ed and 18 others Thank this.
  3. Wicked Wizard
    Wicked Wizard Heavy Load Member
    985
    857
    Jul 15, 2008
    Northeast PA
    For me personally, it wasn't about the work. It was about making money. OTR would be great if I wasn't sitting in some 100 degree pee lot waiting all day for a load only to be told to contact dispatch in the morning. At least now if I am not making money I am home with the family.
    To tell you the truth, I look forward to a 10 hour day. I usually run 12 to 15 hours a day. I hardly got that OTR. I also hated to find a parking spot after 5pm in the northeast. Now I just park the truck and walk to my car...
    tman78 and Honch Thank this.
  4. 201
    201 Road Train Member
    12,288
    25,102
    Apr 16, 2014
    high plains colorado
    I agree with Col.Green about informing new drivers. There's a huge misconception as to local driving being 9-5. In all my years of trucking, I was always a "local" driver, and did every kind of trucking. The only trucking job that came close to "regular" hours, was dump truck. Generally start @ 6am done by 4pm.,although, I did do dump work, that was a 24 hour deal( load out of hoppers, del. to factories)(tanker, same deal) Van/reefer was probably the hardest. Up at midnight, drive 4-5 hours to get to a warehouse, or several warehouses, back by 2,3,or 4pm,especially depending on backhauls & depending on what other hassles you ran into( remember, you're not the only one doing that)have supper, catch the kids little league game, try and catch some z's, up at midnight, to do it again. Haven't done that in years, but to this day, I still wake up at midnight or 1am. Flatbed (or tanker) was probably the most predictable, because most of the time, people were waiting for your stuff, but same thing. Best thing about local tanker/flatbed, usually, deliver load and come back empty. So there you have it, good luck.
    Marksteven Thanks this.
  5. kemosabi49
    10,628
    45,510
    Jan 13, 2013
    SW Arkansas
    I run local/regional, home most nights. I work more hrs and longer hrs than I ever did OTR. I run tanker and go to mostly the same group of places though not the same ones daily, so there is some variety. It's a tradeoff, home or OTR. I ran @15 yrs OTR, stayed out sometimes for weeks and just got tired of it. Some people I talk to that come thought my terminal that went back OTR after running local. Just didn't like it.
  6. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    Good information.....feel the same way about many things . My drive was money. There's no escaping the fact that the shorter the run the more you make...however you get there. Be it from less fuel and miles to local repair prices and parts being stable.
    I'm a local tanker guy...and no not gas. Chemicals ! Pre loads, short hops etc. Sometimes with a hose and pump, mostly not and it does get physical. But no biggie.
    The biggest local thing for me is the FSC. It's my profit. If I take the rate for X and the carrier gets his cut, plus fuel and 25% for me as driver then maintenance there is nothing left for me the owner.....except for FSC. Now if I ran out of the commercial zone, say 500 R/T then the fuel cost would climb and lower my profit. The billed miles and FSC do not follow the actual work being done equally. Miles drive fuel, maintenance and labor.
    It has taken me a few years to refine this model and it works. Some of my co-conspirators take everything everywhere to drive the Friday number, I don't. I consider time, wear and tear plus fuel in every decision and it comes out like this....at the end of the year yes my buddy grossed more than I but if you take all his numbers and all my numbers I kept a much higher percent of the revenue stream...by staying local.
    JMO
    rockyroad74 Thanks this.
  7. Flatbedder73
    Flatbedder73 Medium Load Member
    464
    354
    Dec 30, 2012
    Langhorne, PA
    I ran local chem tanker, had to switch to regional so I would know what day it was.
  8. GenericUserName
    GenericUserName Road Train Member
    1,543
    13,065
    May 17, 2014
    Santa Monica, CA
    Can you elaborate on what you mean by this please?
  9. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    every branch of trucking has good and bad
    I have no intention of loading or unloading trucks in my 60's
    enough of that in my 20's
    I run reefer now WI to CA and back
    I know when I leave the load coming back and take 2-3 days off after I get back
    just right for me
  10. Y2K
    Y2K Road Train Member
    1,654
    1,055
    Jul 21, 2009
    Yacolt,WA
    Good post CG although with some jobs you never have an overnighter, I'm home every night! :biggrin_25525:
  11. 2BucTruck
    2BucTruck Medium Load Member
    481
    545
    Jun 7, 2014
    Eastern USA - Go Bucs!
    Great post OP. I don't think it could be stressed enough for new drivers that local work has its own challenges - to each their own. A challenge for one driver might be another driver's highlight of the day. For the most part, the trade-off is being home daily. But the question needs to be asked by the driver, what is my definition of quality home time? For some, it's better to be gone longer stretches of time from home to enjoy a clump of days all together for home time. For others, just being home on a daily basis is worth it, even if they're dog tired and don't do much but eat and sleep. Typically they'll have 2 days off during the week where they can have more time to do whatever.
    Interestingly enough, some claim you'll make more OTR. I haven't found that to be the case. True, there's some local trucking jobs that don't pay much compared to OTR. But there are plenty of opportunities - depending where you live - that offer a higher income. I'm thinking mainly the LTL sector.
    Speaking of LTL, you left out one particular "local" job that I see as the most attractive - for me. It's the perfect compromise between OTR and a local job like P&D. Linehaul.
    Get a good linehaul gig, and not only are you doing mostly driving, depending on the company it might be exclusively driving, and you're potentially making more than a P&D driver and an OTR driver. Get enough time in w/ your company or just possibly fall into a fortunate situation, and you could also have a linehaul gig that gets you home daily AND is day shift - some don't mind the night shift though. There you have it, what most drivers would consider a dream job. Day hours, home daily, nothing but driving, terminal to terminal, and off 1 or 2 days a week. For some, the monotony of the same run allows a comfortable routine - just drive and get paid for it. You're still going to probably be working 12-14 hour days, but you're mostly just driving.
    Shaggy Thanks this.
