Solar Panels on Trucks and Trailers
Discussion in 'Ask An Owner Operator' started by Dice1, Mar 14, 2013.
  1. Dice1
    Dice1 Road Train Member
    1,315
    609
    Jul 1, 2011
    Bessemer City, NC
    My friend JW posted this over on Kevin Rutherford's website and I knew some here where interested in this technology.
    JW has been working with me on this on where to get these panels and is the first to have these installed just in time to show at MATS.
    I have been too busy moving into a 10,000 sf home and have not had a chance to install my panels to the roof of my Volvo 770.
    Note: JW is using higher voltage to get back to a charge controller that will reduce the voltage (with a higher wattage) to the 12 volt batteries and truck system. Higher voltage from panels to charge controller keeps the wire size down for a long distance wire run.
    slavcha Thanks this.
  3. Dice1
    1,315
    609
    Jul 1, 2011
    Bessemer City, NC
    More pictures:
  4. G/MAN
    G/MAN Road Train Member
    7,031
    8,621
    Sep 3, 2010
    So, what is the point of putting all those solar panels on the trailer? Is it only to keep the batteries up on the truck?
  5. rickybobby
    rickybobby Road Train Member
    4,843
    6,672
    Jul 10, 2010
    greensboro, nc
  6. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,539
    Jul 30, 2009
    Mapleton Depot,PA
    No mention of what the panels weigh, which may be a factor for some. I have a translucent fibreglass roof on my trailer, so those panels would make it darker inside.
    I am fortunate to be one of those solar powered drivers, that is parked by evening and all night, so when I have the need for engine off power, it is dark, so what good would these panels be then?
  7. FLATBED
    FLATBED Road Train Member
    Maybe he would be better off installing them on his 10,000 sq ft house.
  8. GAlanFink
    GAlanFink Medium Load Member
    334
    271
    May 8, 2012
    Bucks County, PA
    but that would be smart.
  9. kwloo
    kwloo Medium Load Member
    336
    246
    Nov 3, 2011
    eh?
    he moved into the Days Inn. Its all good- he has his own room.
    losttrucker and VisionLogistics Thank this.
  10. Dice1
    1,315
    609
    Jul 1, 2011
    Bessemer City, NC
    I am installing a 12 kw system on the house.
  11. Dice1
    1,315
    609
    Jul 1, 2011
    Bessemer City, NC
    And from the batteries you can run a sleeper AC/heat unit.
