Just looking or any experience regarding these units. Which one is better, which on is more silent. which one withstands the elements better.
Soooo. 14hp Kohler vs 13hp Honda Pony Motors. opinions??
Discussion in 'Heavy Haul Trucking Forum' started by UltraZero, Nov 9, 2016.
Page 1 of 7
Why not put a pto driven wet line. Way less upkeep. Though Personal experience says it's hard to beat a Honda
Nothereoften Thanks this. -
I forgot to add, what about HP vs Flow rate. is HP and pressure important vs Flow rate??
PTO??? sounds expensive. Tank on truck, Extra lines, messy. Not to mention having to integrate with a headache rack. Hmmm..
The one day the pup motor doesn't fire up makes you appreciate a pto more I guess. I have had pup motor rgn and in middle of winter going down bush roads delivering feller bunchers. Getting to the patch open up the cover and the only thing you see is white were a motor should be. That's usually when you tell yourself that your gonna be here a little longer than expected
Nothereoften and Dye Guardian Thank this. -
Nothereoften, Dye Guardian and Wymon Thank this.
We have had both but we had canvas bags made to put over the motors. You have to protect them from all the crap on the roads.
A small engine on a truck is all in how you take care of it ...ignore it and it will ignore you .
Honda, I have had tough times with Kohler even though they were on mowers and not an RGN. It's hard to beat a Honda.
Page 1 of 7
