Spanner wrenches ?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Cat sdp, Jan 14, 2017.
  1. Cat sdp
    Cat sdp . .
    21,069
    73,960
    Apr 8, 2012
    Orion's Belt
    Can someone explain the differance between a adjustable hook and an adjustable pin spanner wrench..?
  3. Blackshack46
    Blackshack46 Road Train Member
    I didnt know there was two types till today. From what I can find, adjustable hook, you can make the hook bigger or smaller. Adjustable pin, means you can put a round pin or a square pin or different sizes of pins.
    It may be they are all one in the same with two different names as well.
    Cat sdp Thanks this.
  4. Cat sdp
    Cat sdp . .
    21,069
    73,960
    Apr 8, 2012
    Orion's Belt
    That must be it because snap-on sells both......
    Tks
    Blackshack46 Thanks this.
  5. KVB
    KVB Heavy Load Member
    877
    2,875
    Jun 30, 2012
    hook is rectangular, for nuts that have slots machined in the outer circumference (as used on wheelbearings)
    pin has round pins, for nuts that have holes drilled in the outer circumference.
    Google images for "skf nut", and you will see what I mean. Most of them have the slots, but some are just round with holes drilled in them
    Maybe this explanation will help..... or just cause more confusion:
    http://www.circuitousroot.com/artifice/fitting/mechanics/tools/pin-wrench/
    Cat sdp, Heavyd and BoxCarKidd Thank this.
