Specific Problem w/signal lamp operation 92 Peterbilt 379
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by sirrepairsalot, Jul 16, 2023.
  1. sirrepairsalot
    sirrepairsalot Light Load Member
    66
    28
    Aug 9, 2018
    Canada
    I have a 92 Pete and the signal lamps are led all the way around, I have installed a new led flasher and grounded it well, Power is present but this thing doesn't want to flash occasionally.. I checked and repaired some suspect wiring I found but nothing out of the ordinary. Operator tells me it doesn't work "when it's cold", which says nothing but is there something about these older trucks and LED Lights?? Am I missing something?
  3. wore out
    wore out Numbered Classic
    16,644
    203,211
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    My 91 you can use LED flashers of any brand make or model. Grounded or not. If it doesn’t have 1 light regular light in signal circuit they will flash never. I just keep a old style stop light wired in each side hid inside the T bar completely outta sight
  4. Sons Hero
    Sons Hero Road Train Member
    2,739
    27,719
    Jan 8, 2021
    Indiana
    Could be a bum light. I’ve had to replace the 1 turn signal on the driver side mirror of my 93 Pete 379 twice, for doing the same thing, and both times warranty replaced the light, and it fixed the problem. Been working fine since January.
  5. sirrepairsalot
    66
    28
    Aug 9, 2018
    Canada
    What is a Old Style Stop Lamp? And What is a TeeBar?
    Thanks for the Reply!
  6. wore out
    16,644
    203,211
    Jun 5, 2013
    Anything with a bulb is an old style. The LED fo not draw enough current to run the flasher so you have to have 1 light per side to get it to flash.
    I have a light bar or t bar on rear that lights go on as well as harness. Has an extra plug for the one light left and right. It’s big enough to put a 4 inch tail light in. I’m not saying this is only way but I am saying I have spent good money after bad trying to do it another way to no avail
    BoxCarKidd Thanks this.
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,518
    6,578
    Aug 26, 2014
    I bought some resistors from O Reiley's years ago. Does the same thing for twenty dollars a side instead of two.
    wore out Thanks this.
  8. lester
    2,930
    7,925
    Jan 2, 2012
    NW, Iowa
    Yeah my 01 I tried everything I could and could not get all LEDs to work either.
    I run incandescent tail lights but they are a pain in the butt. They don't last!
  9. 062
    062 Road Train Member
    6,276
    33,783
    Oct 20, 2013
    I’ve had good luck with the el cheapo’s from pilot. Usually about 1.5-2 years.
  10. skallagrime
    skallagrime Road Train Member
    3,853
    9,925
    Apr 10, 2012
    Indiana
    If youre married to incandescents, you do you, but for 25 bucks you could get a pack of 20 cheapo leds shipped to your house
  11. 062
    6,276
    33,783
    Oct 20, 2013
    Did you not understand the reason for using incandescent lights?
    lester Thanks this.
