spec'ing 53' dry van
Discussion in 'Ask An Owner Operator' started by rollin coal, Mar 4, 2014.
  1. rollin coal
    rollin coal Road Train Member
    13,446
    27,411
    Mar 29, 2008
    TN
    I've got about a year before I need it but I'm going to be buying a new trailer. Is it possible to get an air lift axle under the front tandem? Does it add a lot of weight compared to a typical van? Probably 80% of the miles I turn I'd be able to trailer around on a single axle cutting down on rolling resistance. I've seen a lot of spread axle flats with a front lift axle but never a van with tandem axles.
  3. RedForeman
    RedForeman Momentum Conservationist
    4,875
    22,141
    Jan 30, 2011
    They are available. I saw an ad in Overdrive last month. Hendrickson has a fully automatic system called Smartlift. Link to the brochure.
    Don't know about the weight, but I'd venture a guess it'd be a worthy trade off.
    rollin coal Thanks this.
  4. kw550cat
    kw550cat Medium Load Member
    663
    596
    May 22, 2012
    brooklyn, new york
    You can get whatever you want if you have $. But yes you could get a spread axle van with a lift. There is no real difference underneath so you can get it. Weight wise, it should not be drastic, just another couple of hundred pounds.
  5. rollin coal
    13,446
    27,411
    Mar 29, 2008
    TN
    I was thinking more about something that was manual lift/lower but that is a really much nicer setup. This will be my trailer for the next 10 years from the time I get it and I know the payoff will be there.
    Only catch would be is if my '03 truck has ABS with automatic lift control feature. Would almost prefer a manual setup for simplicity sake.
  6. RedForeman
    4,875
    22,141
    Jan 30, 2011
    When you find out how much it costs extra, please share. I'm afraid to ask LOL
    Steeleandsonfarms Thanks this.
  7. Winkjr
    Winkjr Road Train Member
    1,804
    614
    Oct 18, 2011
    Marlton NJ
    That's pretty neat
  8. rollin coal
    13,446
    27,411
    Mar 29, 2008
    TN
    I'm sure it won't be pretty but I'll shop it and see what I can do. I'll have a trailer nicer and worth more than my truck lol. But the payoff is there I know it. Used 53' vans are a dime a dozen but the devil is in the details with specs. I need certain things for what I do and have a enough customers who will not load older than 10 years trailer. If I could get by with a 2000 year model $3,000 trailer I certainly would. Lift axle seems like a no-brainer to save a lot of fuel.
  9. Lone Ranger 13
    Lone Ranger 13 Road Train Member
    1,542
    1,298
    Sep 27, 2012
    Asheville, NC
    I remember there is a beverage cup manufacturer that has lift axles on their tractors and trailers. I think their rigs are black. In the midwest I think. So there's an example.
  10. haycarter
    haycarter Road Train Member
    1,920
    5,317
    Jun 9, 2012
    Australia
  11. EZX1100
    EZX1100 Road Train Member
    4,017
    5,712
    Aug 18, 2012
    just out of curiosity
    what type of floor and walls are you getting?
    i spoke to a trailer repairman some years ago, he said the best thing out there is a wabash duraplate and a stoughton z plate
    he also suggested keeping wood baseboards because once that metal starts to bend, its over
    bbechtel16 Thanks this.
