Speed issue
Discussion in 'Peterbilt Forum' started by hawgfan, Jun 30, 2014.
  1. hawgfan
    hawgfan Bobtail Member
    11
    I am driving a 386 with a Cummins ISX and the computer is set at 65 but every GPS I check the speed with says 62 to 63 on the cruise. Does anyone have any ideas on what could be causing the issue so I can prove to my employer that it is costing both of us money, losing 3 miles every hour adds up. Thanks
  3. 8thnote
    8thnote Road Train Member
    1,980
    3,687
    Aug 12, 2013
    Chattanooga, TN
    It's most likely saving your employer money on fuel.
  4. hawgfan
    11
    It sucks watching our other truck drive out of sight and there's nothing I can do. It's kind of unfair it can cost me around 200 a month in lost income
  5. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    if the computer is hooked up he can see how fast you went all day
    when you shifted and stopped
  6. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Does the speedo say 65? If so, get the make/model/size of the drive tires. Most tire manufacturers publish revs per mile on their website, get that number. Then you have to hook it up to Insite and verify that the revs per mile are correct, if not, correct it.
    As far as proving to your employer, all you can do is run convince him to ride with you and run a set distance and show him that miles are racking up faster than mile markers. I'd do that myself first just to double check the GPS. My GPS is a few miles per hour off too, but the miles show correct on it. I do not know the algorithm they use to figure speed, but it may not be perfect. Double check using mile markers, then raise a stink.
  7. hawgfan
    11
    I think they just looked at the parameters and that is all, I think the speed sensor is bad, if the speedometer says 10 my gps says 7, if it says 50 the gps says 47 and that is every gps I try
  8. hawgfan
    11
    yes the speedo says 65
  9. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    whats does the speedometer say? Most likley the tires are smaller or worn. If the truck thinks it going 65, it wont let you go faster, even if its wrong. GPS speed has nothign to do with axle speed and thus is more accurate.
  10. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    I don't think that you have a bad speedo sensor becasue it sounds very consistent, they do not fail like that. It's very odd that the speed is 3 MPH off at all speeds though. Usually they are farther off the faster you go. 3 MPH off at 50, would be about 1.5 MPH off at 25 MPH. No mater how wrong a parameter is set, one speed that will always be correct is zero MPH, then it spreads from there, the faster you go, the more it will be off.
    Anyway, verifying parameters is more than just looking to see if it set to 65. Gear ratio and tire revs per mile are the big factors to look at. Get the tire brand and look up the revs per mile. Have them verify that it is correct.
    For the recorod, we have about a 4 MPH spread on our 255/70R22.5 drives. Brand new, the actual speed is about 2 MPH faster at 75 MPH. At 3-4/32" (ready to get pulled), actual speed is about 2 MPH slower at 75 MPH.
    3 MPH slower at 65 will taller rubber is not terrible if your tires are close to needing to be replaced. You will gain 4-5 MPH with brand new rubber. Cummins does have a tire wear factor that can be programmed, but I have never seen anyone actually use it. You may be able to talk you employer into setting it up. This will keep your speedo more accurate throughout the drive tires life.
