Hi Guys, I'm picking up a ld. Thurs. going into Ont..
My trk, does not have a speed limit per say. I understand I need this or what is the rules on U.S. trks,. going into Ont.??
Thanks
speed limiter in Ont.
Discussion in 'Canadian Truckers Forum' started by passingthru69, Apr 18, 2012.
Law says ALL trucks must be speed-limited to a maximum 105 kph in Ontario.
Many are not so I wouldn't worry too much as long as you don't get caught running faster than 105. -
105kmh, thats roughly 63mpg
They have plugged into my truck at 3 different Ontario scales to be sure my speed limiter was set . It only takes about 5 minutes
I have a friend who can't flash his pickup ECM because of a voltage issue. Another is a mechanic and has had to get power to an OBDII plug because of a bad wire on several trucks. -
Well I went to get my speed turned down. sat longer waiting to get in. Then go to get the ld. and it was a cluster. Trk. ordered not used. Back I go to turn up the speed again..
omg, what a waste!
sounds like you'll turn down the next load up here, dont blame ya! -
No I wil go. Been running western Sk. / Ab. No speed limiter law there..
Just been about 8 years since I've been on the eastern side of Canada.
Ld. had a good rate to it. Covered the bobtail out as it was a towaway. Just ended up over 14'8" in height. Was to be legal hgt. was to be 14'1 wide ended up at 13'1"
But no working brakes and a few other issues. Somebody else will get it after they cut part of the unit down to lower the height and get the other issues fixed.
I still made out ok for the time spent there..did not lose any money on it.. -
whatever you do if u come to ontario or que. dont go over 115km/h or you'll get a ticket either way cause over that they are allowed to assume you dont have your truck limited to 105
I don't have won I just keep it under 105 never been checked yet
