Speedo/cruise control problem
Discussion in 'Volvo Forum' started by Fidus, Jun 17, 2016.
  1. Fidus
    Fidus Bobtail Member
    18
    4
    Jun 17, 2016
    Franklin Park, IL
    I have a 2006 Volvo VNL with an ISX motor and a Meritor 10 speed. In the past few days a few weird things started happening all at thesame time (which makes it harder to pinpoint the problem). After hitting 50mph my speedo is hunting usually hovering around + - 5mph from actual speed. When in cruise control it hill hunt on rpms and cruise keeps shutting off. I replaced the speedo sensor on the transmission and no change. Cruise works fine when parked. Also my truck is governed at 65 but there are times it will cut off at 60 or 62 like it was governed at that speed. My fear is that the ecu has gone bad and im hoping it could be something smaller. Please help, i do a lot of the work myself on the truck so any sensor, wiring harness i could change my self before i go and spend crazy money on an ecu at a dealer.
  3. boneebone
    boneebone Road Train Member
    2,297
    2,371
    Mar 13, 2009
    Check and replace Pedal Position Sensor and/ or worn out Accelerator Pedal.
  4. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    check to see if the Eciter ring in the back of your trans is loose just try to move from sensor hole with screwdriver if not then check the wiring from transmission to under driver seat in the cab that's where it goes in. another thing make sure if you have any old qualcomm wires if so then remove them they make a lot of really weird ####
  5. blr300
    blr300 Light Load Member
    76
    30
    Jan 5, 2014
    St. Thomas Ont. Canada
    check your ground wire from motor to frame and frame to cab. They are cheap.....and clean the studs as well before replacing the ground wire. I hope you got it fixed, but after replacing everything and with no result, the new grounds did fix my problem. Good luck
  6. QUALITYTRUCK
    1,817
    1,783
    Jun 14, 2009
    romulus,mi
