I have an 05 pete 379, my speedometer has been fluctuating from 0 to 40, 50, 10 basically all over the place. I've changed the sensor, the plug on the sensor wires, checked all the wires and the ecm plugs. Everything seems fine there. The cruise won't work cause it's trying to work off the what the speedo is reading, same thing With the jake. I've even unplugged the speedo behind the dash and that doesn't change anything
Speedo fluctuates and cruise and jake won't work
Discussion in 'Peterbilt Forum' started by Hertz309, Apr 17, 2017.
Make sure that the trans yoke is tight, the VSS tone ring can spin on the shaft when it comes loose.
Probably like Grapeape Said tone ring is loose
Have checked it and the nut will not budge. Been bouncing down a rough highway today and it suddenly reads right for half a minute or so then goes back down, and when it climbs to my current speed it does it at a steady pace
SWAG I had same problem How many miles on Trans? You ain't gonna like this but a tone ring covered with ground up trans guts will do this some times a rough road knocks some loose. Oh yeah loose plug or wire at trans or rubbed bouncing sensor wire.took trans out and rebuilt installed OOUUCCHH! kittypower
