Speedometer and cruise issues after clutch replacement. HELP!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by silver dollar, Dec 1, 2013.
  1. silver dollar
    silver dollar Medium Load Member
    481
    210
    Jan 31, 2009
    Central North Carolina
    Truck is a 2002 Int'l 9400, C15 and Eaton 10 speed. Had no issues with speedometer or cruise before repair. Repairs done were; clutch replaced, pilot bearing, resurface flywheel, trans input shaft and bearing, range syncros and a couple of other bearings in trans. I picked up truck last night. It drove and shifted fine. Got on interstate and set cruise at 65. Then after about a mile or so cruise kicked off. That's when I noticed the speedometer was not working. I could set cruise again, and again after a short time it would kick off. Speedometer would bounce once in a while. It would register at 5 mph at 65, then later it was all over the place, then later no movement at all. Eventually cruise would not set at all. I also noticed that without the cruise, it would momentarily lose power; sort of like a miss in the engine.
    I looked under truck nothing seems to be out of place. But truck is so low its hard for me to really get under there good. What could be going on here? Any ideas are welcomed.
    Shop owner said to bring it back on Monday. I would kinda like to know what he will be looking for.
  3. bowtieboy77
    bowtieboy77 Light Load Member
    274
    82
    Aug 16, 2013
    Southern, Ontario
    Sounds like speed sensor on back of trans.
    silver dollar Thanks this.
  4. Freightlinerbob
    Freightlinerbob Road Train Member
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    There is a speed sensor on the output shaft of the transmission that "reads " off a collar that sits between the yoke and the trans. This would have been removed and it's likely that the sensor has not been properly hooked up.
  5. Heavyd
    Heavyd Road Train Member
    7,804
    6,253
    Feb 4, 2009
    Yep, something funny with the speedo sensor or wiring to it. Those sensors have just a plastic body now and doesn't take much to break them. It may have gotten bumped and therefore cracked when they were r&r the trans. The wiring connector could simply be loose too.
  6. Ridgeline
    22,603
    120,016
    They messed up the sensor, so they should replace it.
  7. silver dollar
    481
    210
    Jan 31, 2009
    shop owner just called. Said the same as you. I was just worried that trans may have to be removed. Resulting in more down time. Thanks.
    Heavyd Thanks this.
  8. silver dollar
    481
    210
    Jan 31, 2009
    Shop owner said he fix problem no charge, even if sensor need replacement. When I get to shop he would get to it then, no waiting. Thanks for the reply.
  9. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Well they shouldnt have made the mistake int he first place, but at lest they are gonns fix it. Sucks to have any down time while its in the shop though.
  10. Jose Castaneda
    Jose Castaneda Bobtail Member
    I have the same problem I put a clutch on on my truck and now speedometer is not working
