Split sleeper berth help
Discussion in 'Experienced Truckers' Advice' started by ashtre, Aug 29, 2019.
  1. ashtre
    ashtre Light Load Member
    109
    108
    May 9, 2016
    10 hr break
    Drove 3 hrs
    2 hr break
    Drove 7.5 hrs
    8 hr break
    Now i need to drive 2 more hrs for delivery.
    If i take another 2 hr break after i deliver, will i get anything back?
  3. 25(2)+2
    18,756
    45,834
    Sep 18, 2006
    the road less travelled
    Off the cuff, you'll have 3.5 hours left and then another 8 or more sleeper to get more, you can do ithat indefinitely, if things work out.
    tinytim and LoSt_AgAiN Thank this.
  4. ashtre
    109
    108
    May 9, 2016
    Sweet i'll get three and a half again after 2nd 2 hr break sweet. Thnx just need 3 hrs to get to my weekend reload. Thnx
    25(2)+2 Thanks this.
  5. ashtre
    109
    108
    May 9, 2016
    Sorry for the redundancy. Sweet.
  6. 25(2)+2
    18,756
    45,834
    Sep 18, 2006
    If you have ELD, it should figure the hours correctly, and if your situation allows it.
    Mine wasn't right until they started supplying data to the FMCSA, and then it magically got fixed, other than connectivity issues.
    Bean Jr. Thanks this.
  7. mustang190
    mustang190 Road Train Member
    2,876
    6,195
    Jan 18, 2011
    Florida Panhandle
    I still haven’t figured out that ridiculous split stuff.
    D.Tibbitt Thanks this.
  8. FoolsErrand
    FoolsErrand Road Train Member
    2,877
    12,169
    Sep 15, 2017
  9. MichaelSemiTruckDriver
    MichaelSemiTruckDriver Bobtail Member
    20
    38
    Aug 27, 2019
    Minimum 2hr break, drive, rest for 8hrs, get back everything prior to 2hr break. After 8hr break I forget if full 10hr is needed. I think is how it works,
    Haven't been able to do one for almost a yr, usually on go with minimal hold ups. Use to do them all the time ;)
    Edit: get back everything unused and prior to 2hr break out of 11hr drive line. Between 2hr break and 8hr break drive time is still part of the 11. Hope this better explains than original response above of mine
    FlaSwampRat Thanks this.
  10. mustang190
    2,876
    6,195
    Jan 18, 2011
    Florida Panhandle
    How about this, drive till you start feeling tired, take a break or a nap. Drive some more? Then at the end of your day, go sleep as long as you want too??
    But then again, a man has to know his limitations.
    D.Tibbitt and FlaSwampRat Thank this.
  11. FoolsErrand
    2,877
    12,169
    Sep 15, 2017
    Thats called loose leaf, works great until you hit something and they want to see your phone.
