I am on E logs. I am making a 13 hour run. I would like to split sleeper as it will be at least a couple of hours on the dock. What would be the best formula? Thanks
Split Sleeper Question
Discussion in 'Questions From New Drivers' started by MojoPotatoe, Dec 26, 2011.
A little more info, Fremont Indiana to Hartford Ct. 4am delivery
The old rules of splitting no longer apply.MojoPotatoe Thanks this. -
If I understand correctly, 8 in the sleeper will not add to my 11. I will have to take 10 off to get more drive time. Correct?
Splitting with e-logs can be pretty easy...
On the qualicom it does it on mine,by just pausing the 14 hrs when you take the 8....so you must have time left to run when you stop...or you need to complete the 10...
then when you start again, yo can finish the time you had left on your 14...the main plus is you recouo the time you were not onduty towards your 14 that you were off dutyfor. Since you will be running hard, no real change...you do not cover miles faster with an 8/2 split....you mearly can do for example 8 in a roadside reststop....then drive, then do 2 at a truckstop, get a shower and food, and not loose time on your 14....
with my qualicom, it gives me my fresh driving time st the completion of the 10...
So after you do an 8, tjen the two, you will get some drive time back....and it calculates it by looking at the hrs before and previous break...and that will be you total.it gives you to run before you must stop.....you basicly get 2x the chsnces to get a violation.......can be useful, but the isdue is, you can be in the sleeper at a shipper/reciever, but not really off duty....MojoPotatoe Thanks this. -
Thanks Zippy, Precision, To the point, Crystal clear. I appreciate your time.
Thanks for the tip Sonny! Instead I just called your" Momma" I will see you at the next family function you attend. BTW your "Momma" said you were a bad boy that is why all you received for Christmas was a chunk of coal. Cya.
JustSonny Thanks this.
