Splitter stuck
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Debroy, Jan 3, 2018.
  1. Debroy
    Debroy Bobtail Member
    29
    Ok with temps so cold we have no air to splitter ....air horn ...seats ....brakes are no problem....splitter is stuck in high side....2007 freightliner columbia....any suggestions...we've used air line antifreeze and alcohol
  3. IH Truck Guy
    4,336
    49,604
    Mar 2, 2008
    Purgatory
    Pull the supply line off the compressor and fill it with airline antifreeze. That way it will thaw out the whole system if you can't get it in a warm shop.
    If it's really iced up,you will have to get under the truck and start heating valves and fittings with a torch.
    Just be careful of the plastic.
    SAR, Lepton1 and ShooterK2 Thank this.
  4. Debroy
    29
    We've done that to....but thank you
  5. fortycalglock
    fortycalglock Road Train Member
    6,153
    6,583
    Jun 25, 2011
    Tourist Town, FL
    You need to find the supply line and find where the blockage is. Pour some room temp water OVER the frozen valve and it should thaw. High idle like 1200 rpm and cycling through your air for 10 minutes might provide enough heat to thaw it out as well
  6. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    If pressure puts it into the high range, find the vent. Might be iced up/blocked. Remove, and it should work. Thaw it out inside the cab and then replace it once cleaned out & dry to keep crap from entering in through the fitting's hole.
  7. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,543
    May 22, 2017
    I wonder if your compressor is tired?
  8. Oldironfan
    5,777
    5,543
    May 22, 2017
    May need new air dryer also.
  9. Debroy
    29
    My bad.. .it's stuck in low....
  10. Debroy
    29
    Well seems like we have done all of this....except for vent....where os that
  11. Oldironfan
    5,777
    5,543
    May 22, 2017
    Vent is at bottom of dryer usually. The thing that makes wooooose sound when it reaches 120 psi.
