Spn 274203 fmi 5
Discussion in 'Ask An Owner Operator' started by feldsforever, Mar 13, 2021.
  1. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    2016 freight liner cascadia.dd13. I can't find this code anywhere.
    At idle rpms bouncing between 5500 rpms and 6k. Then will level off and do it again.
    About six months ago injector 4 was replaced. But the serial number of the injector had not been entered in yet. I don't think that's the cause, namely because this is only a day or two new issue.
    I down loaded two spn code books and could not find it. Ill let the boss know Tommrow. But if its something I can tighten or clean id rather not give another 4 hours to the T A.
    Any help would be fantastic. Thanks in advance.
    Edit: I just tested the high idle. It has the same 500ish rpm variance.
    iggybest and 77fib77 Thank this.
  3. Ridgeline
    22,315
    115,452
    The error comes up as a suspension air ride error. Axle 3, left sensor, open or low current harness/sensor issue.
  4. danny23tx
    danny23tx Road Train Member
    1,494
    2,324
    Feb 16, 2016
    Austin,Tx
    Fuel quantity valve might be your culprit , maybe the code is for something else.
  5. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Thanks guys.!!
    @Ridgeline where did you find the code?
  6. Ridgeline
    22,315
    115,452
    My webco manual, it is what freightliner and western star use for electric controlled air suspension.
  7. AModelCat
    157,188
    If she's turning at 6k RPM when idling you've got bigger problems than an air ride sensor lol.
    A Google search can usually pull up code descriptions. Everything electronic on a truck "talks" with the same language so all the codes are more or less standardized regardless of manufacturer.
  8. 77fib77
    77fib77 Road Train Member
    10,379
    64,763
    Jul 7, 2010
    St Louis
    It's a fast truck.
  9. feldsforever
    1,453
    1,440
    Nov 22, 2019
    @AModelCat . lmao
    Good catch didn't realise I added a extra 0.
    77fib77 Thanks this.
  10. Keepforgettingmypassword
    Keepforgettingmypassword Heavy Load Member
    738
    937
    Jan 11, 2022
    Where can I get a manual, maybe I'm looking in the wrong places?
