SPN 412 FMI 5 Fault code
Discussion in 'Trucks [ Eighteen Wheelers ]' started by AlexD13, Jan 12, 2017.
  1. AlexD13
    AlexD13 Light Load Member
    298
    85
    Jun 13, 2016
    Hi Everyone, Just got this Fault code on my dash with a Check Engine light on. Going to mechanic later on today, but wanted to see if anyone knows anything about this fault code. Forgot to Mention I have a 2012 Volvo D 13
    Thanks
  3. driverdriver
    driverdriver Road Train Member
    4,254
    5,283
    May 30, 2011
    Type into your browser hit search
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    SPN 412 is EGR temp sensor circuit. FMI 5 is low current or open circuit. Could be bad wiring, a bad connection in a plug, or a failed sensor.
    AlexD13 Thanks this.
  5. AlexD13
    298
    85
    Jun 13, 2016
    I did, not much information came up, wich is why I came here...
  6. Tone1701
    Tone1701 Bobtail Member
    It may take some searching, but I found a service manual that I downloaded. It's 74 pages. Has every spn and fmi code for volvo trucks. I just had my EGR replaced along with sensors and still getting spn 412 show up on my 2012 d11. Check out the wiring loom that wraps around the front of the engine toward the driver's side. My zip tie must have snapped because the plastic loom was resting against a metal radiator pipe and the plastic was melted. I'll get that replaced next. Only other thing it could be.
    Good luck
  7. AlexD13
    298
    85
    Jun 13, 2016
    Was the egr itself
    QUALITYTRUCK Thanks this.
