spn 520371 fmi 16
Discussion in 'Freightliner Forum' started by AlexD13, Oct 18, 2021.
  1. AlexD13
    AlexD13 Light Load Member
    298
    85
    Jun 13, 2016
    hi everyone, changed my DPF filters and the next day , I got a check engine light on. No codes until I got to mechanic and he pulled this up. wondering what it might be . He is not quit sure either but its something to do with poor def quality.
  3. Ross_Tech
    Ross_Tech Light Load Member
    133
    133
    Aug 31, 2021
    Did you replace the DPF's for preventive maintenance, or was there a fault?
  4. AlexD13
    298
    85
    Jun 13, 2016
    Preventative Maintenance
  5. Ross_Tech
    133
    133
    Aug 31, 2021
    I would verify that the DOC inlet temp sensor wasn't damaged and pull the cover off and check for leaks, and that the clamps are situated correctly. It can be tricky in a one box to get the inside front clamp on there properly.
    AlexD13 Thanks this.
  6. AlexD13
    298
    85
    Jun 13, 2016
    I will have the mechanic look into it. I haven’t lost power or anything. Im hoping its minor
  7. Dym4k
    Dym4k Bobtail Member
    Hello
    Did you find the issue?
    I'm having the same code
  8. armo
    armo Light Load Member
    274
    290
    Jun 16, 2022
    what year is your truck?
  9. armo
    274
    290
    Jun 16, 2022
    Troubleshooting of this code
