Spread Axel Flatbed Problem
Discussion in 'Flatbed Trucking Forum' started by crackinwise, Jan 24, 2015.
  1. crackinwise
    crackinwise Medium Load Member
    479
    238
    Aug 21, 2011
    Central Florida
    I have a 48ft Chaparrel Flatbed 2001. It has a 10'2" spread and the issue is on the drivers side.. Front axel.. That set of duels will lock up while Im coming to a stop. All the other wheels will be spinning as I slow but that one set will be locked up...
    Mechanics replaced a leveler valve and the same problem happened next trip out. Then they removed, took apart and cleaned out the ABS valve. The problem seemed to go away for a few trips then came back again as I was slowing for a red light. Once it starts happening then it happens at almost every stop.. Usually about 10 mph or so.. Also if its necessary to slow quickly that same tire will lock up at higher speeds... Anyone have any idea what could cause this??? Brakes have been adjusted 3 times since early December but the issue continues...
  3. FLHT
    FLHT Road Train Member
    1,410
    2,493
    Aug 2, 2014
    What on that axle has been changed out ?
    Slack adjuster check for travel may have a shorter travel than others.
    Brake Pod
    Springs on shoes broken jammed or missing
    Davidlee Thanks this.
  4. crackinwise
    479
    238
    Aug 21, 2011
    Central Florida
    All has been checked and re adjusted. But the problem keeps occurring.
  5. Ruthless
    Ruthless Road Train Member
    9,104
    90,289
    Aug 28, 2010
    The City.
    Brake chamber the same as the rest? I had that problem, turned out I had one short stroke and 3 long stroke chambers. Swapped it and not a problem since.
  6. jbatmick
    jbatmick Road Train Member
    2,199
    2,507
    Dec 1, 2009
    hastings, Fl
    New brake spring kit fixed my problem like yours.
    cabwrecker Thanks this.
  7. cabwrecker
    cabwrecker The clutch wrecker
    1,626
    1,425
    Mar 23, 2012
    Having this exact problem with my company 53 spread drop deck. Clambered underneath to find 3 completely different types of brake canisters. Imagining this is my issue. Happy accident, not a real issue (she just passed a level 1 about 4 hours ago) but it's pretty aggravating deadheading in icy weather.
    crackinwise Thanks this.
  8. mtoo
    mtoo Road Train Member
    1,936
    4,514
    Jan 15, 2011
    Retired on bended knee
    two things, #1 you could have a slight oil leak at the wheel seal, pull that wheel and check for oil saturation on the brakes. #2 out of round drum, if there is no oil on the brakes, throw a new drum on. I bet it's one of the two.
  9. allisonisatranny
    allisonisatranny Light Load Member
    188
    131
    Oct 6, 2014
    Cam bushings, other components in the brake system...
  10. xsetra
    xsetra Road Train Member
    5,172
    7,108
    Aug 21, 2011
    I was having same issue. The anchor pin on my axles were not replaceable. This is the point were the brake shoes rest and pivot. My brake shoes would wobble inside drum and wedge in the drum. So I had to change both axles.
    zenaddler and crackinwise Thank this.
  11. rank
    rank Road Train Member
    9,919
    113,508
    Feb 11, 2010
    If all the above checks out, maybe the air lines are shorter on that wheel?
