Spread Axle Reefer Question, weight distribution help.
Discussion in 'Ask An Owner Operator' started by ready2truck, Feb 11, 2021.
  1. ready2truck
    ready2truck Medium Load Member
    301
    351
    Oct 27, 2020
    Right now I have tandem axle reefer. When I haul water loads I am heavy on my drives. Tandems are all the way forward and I'm about 1k over on drives because of the way they load the water. Will a spread axle fix this? Getting ready to by another trailer and trying to decide if spread is worth it.
    Empty full of fuel and apu.
    10960 steer
    14600 drives
    9680 trailer
    35240 total
    fifth wheel is adjusted to be a little over 12k on steer full of fuel.
  3. lester
    2,930
    7,925
    Jan 2, 2012
    NW, Iowa
    Can't you ask them to load you differently?
  4. 062
    062 Road Train Member
    6,275
    33,779
    Oct 20, 2013
    It will make the problem worse. Spread axle trailers have to be loaded light in the nose.
    p608 and ready2truck Thank this.
  5. 201
    201 Road Train Member
    12,621
    25,905
    Apr 16, 2014
    high plains colorado
    I heard, with a spread axle wagon, it's almost impossible to be over on the trailer. I thought with a spread, you can go 20K on an axle, or 40K for the wagon. No?
    Speed_Drums and motocross25 Thank this.
  6. 062
    6,275
    33,779
    Oct 20, 2013
    Yes. The trailer isn’t the problem,it’s the way that the load is positioned in the trailer.
    ready2truck and 201 Thank this.
  7. Crazytrucker77
    Crazytrucker77 Heavy Load Member
    848
    1,048
    Nov 23, 2014
    Grants Pass, OR
    I pull a spread axel. Yes you can have 40k on the trailer axels but it's not going to help the nose. It's all in the way they are loading the trailer. I have made shippers fully unload me to fix overweight issues. It is what it is. You will wear tires faster with a spread so think about that also. I generally only get about 12 - 14 months out of the tires on average. Most the time I have to replace them due to them chunking tread off rather then wear.
    201 and ready2truck Thank this.
  8. Eddiec
    Eddiec Road Train Member
    2,284
    3,507
    Feb 2, 2015
    If they are putting two pallets in the nose - change it to one pallet in the nose and put the other pallet in the middle of the trailer as a single.
    Speed_Drums and ready2truck Thank this.
  9. motocross25
    motocross25 Road Train Member
    3,859
    11,775
    Sep 23, 2010
    Overland Park, KS
    I pull a spread axle end dump and to go along with what you’re saying, yes. Unless the loader does something completely ridiculous, if I got 80k back there, I’m legal on axles.
    201 Thanks this.
  10. NorthEastTrucker
    NorthEastTrucker Heavy Load Member
    971
    1,820
    Sep 21, 2019
    Seems like the load has to be loaded 1/2/1in the nose and pull your trailer tandems back 3 to 4 hole spots. With for 44760 (minus your weight eg. 220 leaving you 44540 for your load) try to balance the load by 20% less in the nose.
    ready2truck Thanks this.
  11. ready2truck
    301
    351
    Oct 27, 2020
    The water load was supposedly 43176. I didn't stop for a weight ticket. My load Guage on drives was at around 35k or more.
    When I'm getting loaded do I say "load 1/2/1 on the nose? I was at a robot load facility.
