Spread axle vs. sliding tandem. Pros and cons
Discussion in 'Ask An Owner Operator' started by Wildcat74, Mar 30, 2011.
  1. Wildcat74
    Wildcat74 Medium Load Member
    354
    128
    Jul 15, 2008
    Omaha, NE
    Can someone school me on the pros and cons of these two trailers?
    I know with the spread axle either axle can go up to 20k lbs, correct?
    Is the spread axle set up harder on trailers? It just seems like in a tight turn that it would be putting one of the two axles in some high lateral torque situations, any problems arise from this?
  3. Prairie Boy
    Prairie Boy Road Train Member
    3,258
    1,913
    Nov 18, 2010
    Edmonton, AB
    The spread is a lot harder on tires.
  4. ohio_redneck75
    ohio_redneck75 Light Load Member
    128
    51
    Sep 27, 2010
    coshocton,ohio
    well most spreads i have seen have a drop axle for them sharp turns and all. and i think on a spread your alowed 45000. not sure on that but im sure if it wrong someone here will tell me about it
  5. Allow Me.
    10,643
    12,114
    May 28, 2009
    Rancho Mirage, Ca.
    Forty on a spread, (20k per axle). The front axle will chew up tires unless you take great care when turning. If you have an air bag dump set-up on the front axle, you're better off.
    20 Mule Team Thanks this.
  6. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,663
    16,041
    Jan 18, 2011
    20k per axle=40k on spread
    There is a very good discussion on here a while back about this--can't find it at moment....
  7. rbht
    rbht Heavy Load Member
    888
    525
    Jan 23, 2010
    CT,NH
    I would spec nothing else but a spread for a van, refer, flat or dump. The ride is way better, no real worry about axel wieght just load it heavy to the rear. As far as tire weare i've had no issues with tires on my spread and i run in some tight spots and heavy. If buying new i would spec a dump valve on the rear and a front lift axel.
  8. Diesel Dave
    8,551
    23,736
    Jan 20, 2010
    Hesperia, Ca.
    You can overload on a spread if not careful, refering to an axle. But not usually.
  9. Allow Me.
    10,643
    12,114
    May 28, 2009
    Rancho Mirage, Ca.
    Yeah, I had a coil and some sheet steel on a spread. Was 21k on each axle when crossing the Co. scales. My fault, i could have weighed it at the truck stop close to the shipper. The fine was minimal, but the tow truck shifting the load was a big "ouch". You can be over weight on a spread.
  10. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    ??? Um.....no. Having had spreads with front lift axles they are not better for turning than a rear dump. Dumping or lifting the front axle not only makes your trailer 5' longer but most won't carry the load on the rear axle only.
    I hear a lot of people say this but unless your constantly driving in circles it's not as noticeable as most like to believe. Any added tire wear is easily made up by never having to pay to scale.
    Agreed, if the trailer can be ordered a spread IMO it's worth it. The only trailers we have that aren't spreads are grain hoppers. And that's only because with the exception of Cornhusker all MFG's require them to be a minimum of 48' to get a 10' spread. (cornhusker is like 46') Vans, dumps, reefers all can benefit from the added load carrying capacity of the spread. I've seen a few FIXED tandem flats running around, whoever orders those should be shot. I would love to see even an experienced steel hauler load a heavy coil on one and get it legal.:biggrin_2556:
  11. ‘Olhand
    6,663
    16,041
    Jan 18, 2011
    I also prefer a spread--but I say again BUTTTTTTT-remember you are going to have to pay attention--it works well for me doing lTL with a reefer--or the guys with big pieces on a flat---but especially full loads(in any kind of box)make #### sure the folks loading you know it is a spread--and do not be surprised if you have to explain it to them!
    Most of the regular whse type guys think everyone has a 53 and the typically load them like a 48--So KEEP this in mind and tell people how you Want/Need it loaded!
    just my$.02
    ibcalm19 and PacManTrap Thank this.
