spread axle
Discussion in 'Trucks [ Eighteen Wheelers ]' started by quad737, Feb 22, 2010.
  1. quad737
    quad737 Bobtail Member
    4
    Feb 9, 2010
    ia
    hey i was wondering what you gain by having a spread axle trailer.
  3. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    You can load 40k on a spread and only 34k on a closed tandem.
  4. Eskimo6804
    Eskimo6804 Heavy Load Member
    816
    3,344
    Jun 13, 2007
    Northeast Alabama
    Spreads ride smoother too.
  5. Winchester Magnum
    Winchester Magnum Road Train Member
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
    You will never have to slide tandems again. Huge plus. Once you buy a spread axle, you'll likely never go back to a closed tandem. Plus, at least with a spread reefer, they are hard to load wrong. The front axle of the trailer takes alot of weight off the drives, placing this weight on the trailer where it's more forgiving, given the 40,000 pound limit.
  6. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    Only drawback, the front axle of the trailer, chews up tires at a quicker pace when making tight turns. Solution. Don't make tight turn.
  7. notarps4me
    notarps4me Road Train Member
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    The solution is to be able to flip a switch so that don't happen...:yes2557:
    JimTheHut Thanks this.
  8. Winchester Magnum
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
    Independent quick dumps are your friend
  9. blanco
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
  10. lastgoodusername
    lastgoodusername Medium Load Member
    444
    215
    Dec 18, 2008
    central NC
  11. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    I've never heard of anyone saying "man I sure miss my tandem" after owning a spread. You hardly ever see a truck with a spread on a set of truckstop scales, that alone would pay for it's self with a van/reefer.
