Spring to air ride suspension conversion - pete379
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Hopeaholic, Nov 7, 2018.
  1. Hopeaholic
    Hopeaholic Bobtail Member
    47
    15
    Nov 7, 2018
    hey gang. I'm looking to replace my rough riding Hendrickson rear spring suspension on my 1991 Peterbilt 379 with a low air leaf setup from a frame cutoff that came from a 2003 Peterbilt. My plan is to remove all the old spring components, keep the existing frame and rear tandems, drill appropriate mounting holes and transfer the low air leaf parts. Any words of wisdom on whether this is a good plan would be much appreciated!! Thanks in advance.
    jamespmack Thanks this.
  3. Rideandrepair
    17,340
    56,258
    Aug 8, 2015
    I guess you want to do all the labor otherwise why use the new cut off and stretc it out while you’re at it. I’ve seen it done at the right spot around front spring hangers works good.
    Hopeaholic and snowman_w900 Thank this.
  4. Rideandrepair
    17,340
    56,258
    Aug 8, 2015
  5. Hopeaholic
    47
    15
    Nov 7, 2018
    Yes hoping to do myself and wouldn't be too excited about splicing the frame.
    Rideandrepair Thanks this.
  6. lester
    2,920
    7,890
    Jan 2, 2012
    NW, Iowa
    Be a lot of empty holes and alot of new holes. I'd say depending on the condition of your current frame I'd just cut your old one off and weld in the new one. Think that would be easier. Decent job either way
  7. 201
    201 Road Train Member
    12,334
    25,217
    Apr 16, 2014
    high plains colorado
    I did that, or had that done, to my '82 Western Star. conv. It originally had that White "Reyco", and after a month of breaking springs in Chicago, I said, "that's it". I had a rear stub from a 362 spliced into the WS frame. It made a world of difference. Sounds like a lot of hassle what you want to do. I agree, cut the back off behind the cab, get 2 inner rails for inside your ( and the stubs) frame, maybe stretch it a bit, perfect time to for a better ride, bolt and weld, it will be almost like a double frame. I never had a problem with that setup and I hauled a lot of heavy rail cans.
    speedyk, Hopeaholic and Bean Jr. Thank this.
  8. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    It’s going to be less labor and much easier to cut off the Hendrickson and splice in the low air leaf.
    adayrider and Hopeaholic Thank this.
  9. Hopeaholic
    47
    15
    Nov 7, 2018
    Should have mentioned the donor tandem differentials are gutted and I'm not a welder. Might that change the calculus on level of effort and labor cost?
    Thanks for all the responses so far.
  10. 201
    12,334
    25,217
    Apr 16, 2014
    Yeah, that could change it somewhat. Not a simple swap, pulling carriers and such. Just so you know, it's a female dog drilling holes in frame rails. Best thing is to rent one of those hole shooters that clamp the frame and about 20, 3/4 inch drill bits.:mad:
  11. Rideandrepair
    17,340
    56,258
    Aug 8, 2015
    I had some holes drilled once for mud flap hangers. The guy drilled smaller holes first then used a reamer bit that really worked good
    Hopeaholic and AModelCat Thank this.
