Squealing at high rpm or jake usage
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Oklahoma1, Jun 18, 2024.
  1. Oklahoma1
    Oklahoma1 Bobtail Member
    4
    Jun 18, 2024
    As of a few months ago I got a new truck, 2022 Kenworth T680. It's been a really good rig up until last night I started it up and got this horrible squealing anytime the Jake's were used and it would hit higher rpms or if it was accelerating from 5th to 6th gear. It's never had this problem before but in a ten hour period it just came on suddenly. Any help would be appreciated, thank yall!
  3. The one california kid
    The one california kid Medium Load Member
    560
    936
    Oct 31, 2023
    I warned you not to run those jakes at 2am going by my place! Soooo, I found a radio shack (still open what a find!) and i installed a little high pitched whistler doodad down there underneath all those wires -n stuff! LoL honestly though that sounds like maybe an air hose has a small pinhole in it somewhere, and it's so small it only opens up and whines like that when there's enough pressure going thru the line. If that makes any sense to ys. And I'm not sure how you could test that theory .
  4. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,750
    16,653
    Jan 18, 2011
    Is it a squel? Like a belt
    Or a whine like air??
  5. Big Road Skateboard
    6,718
    37,824
    May 2, 2021
    Probably a boost leak. Check your hoses and clamps from the turbo to CAC and CAC to intake
  6. Heavyd
    Heavyd Road Train Member
    7,811
    6,264
    Feb 4, 2009
    Turbo flange or exhaust leak.
  7. Oklahoma1
    4
    Jun 18, 2024
    Thank ya! I reckon I might try to run a bit of soap over when its goin so I can have a bit of a bubble form, I reckon itd be worth a shot.
    The one california kid Thanks this.
  8. Oklahoma1
    4
    Jun 18, 2024
    At first I thought it was a belt so I've kept an eye on it but now I'm not too sure because for the few seconds in the beginning its sounding like metal on metal but I know it cant be the case, maybe air from some sorta blowback maybe?
  9. Oklahoma1
    4
    Jun 18, 2024
    Thank you I'll definitely check this to make sure they're sealed down tight!
