I have Connex 3300 I just put in a 379 pete when I turn my park or headlights on I get a real bad squeal. Once I touch the switches or grab the case of the radio it stops any clues.
Squealing CB
Discussion in 'CB Radio Forum' started by coulds, Mar 13, 2013.
Sounds like a bad ground to me. Try running a ground wire to a bolt or a screw somewhere that goes into the metal body of the truck, and see if that fixes it. If not, it could be internal.... a bad solder on the ground connection to the board or something similar.
coulds Thanks this. -
ok thanks for the info I will try that and see what happens
I second a bad ground
I knew you would and I agree!
