Squealing Turbo
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Oscar the KW, Sep 1, 2013.
  1. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    Every now and then when I am getting into the throttle and building boost it sounds like one of the turbos starts to squeal, lift off the throttle and it goes away, most of the time when you roll back into it, it will squeal again, once full boost is hit it will go away. It doesn't do this all the time, comes and goes, seems to do it more when taking off from a stop, any thoughts? This is on a BXS Acert Cat.
  3. morehp
    morehp Medium Load Member
    699
    206
    Jun 18, 2012
    Checking bellows for cracks would be a good start, possibly turbo mounting gasket on its way out, or exhaust manifold leak, start with them and then check out both compressor wheels and make sure they haven't touched the housings!
  4. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    Have you upgraded tour boot clamps? I cant keep the "stock" clamps tight enough to stay sealed above 40 psi. I just double clamped mine I can't find the ones with the 1" spring.(I haven't looked very hard either) I got rid of a lot of my original issues when I replaced the little blue hose and clamps that runs between the two turbos and operates the waste-gate/actuator. My BXS makes about 40-45 psi in the heat and 50-55 on crisp cool morning, I guessing your up around 60-65 with the BD. By the way I've been meaning to ask you does BD put enough timing back in it to cool the exhaust off any?
  5. Heavyd
    Heavyd Road Train Member
    7,752
    6,186
    Feb 4, 2009
    Yep, sounds like a pressure leak. Could be anywhere, but most likely turbo flange, exhaust manifold or air to air boot/clamp.
  6. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,729
    Jan 30, 2010
    keep stroking.
    i had the same problem. thought it was a turbo. ended up being the serpentine belt slipping when fan was engaged. try it sitting still at high idle and turn fan on and off with manual switch to see if squeal goes away. dirt gets in the groves of the pulleys and lets it slip.
    wore out Thanks this.
  7. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    Check the turbos for shaft play. Disconnect the intake and grab the impeller and try to push it in and out and up and down. See if it wiggles in any way. The fins could be hitting the side of the turbo.
    or it could be a intake gasket going out, clamp, boot or the cooler.
  8. kalh7
    kalh7 Light Load Member
    186
    62
    Mar 28, 2007
    southern illinois
    Had the same issue on a bxs. It was a stud on the exhaust manifold that broke. When in low boost it would "squeal" til the boost got higher.
  9. Oscar the KW
    12,246
    28,114
    May 19, 2011
    Checked all of the bellows, they all appear to be fine, anytime I have had one of them crack they always hiss, like an air leak. All the gaskets on turbos and the manifold don't show any signs of leaking, no soot streaks.
    This is what I thought first, tightened all of the clamps up, and still get the noise intermittently. I do have upgraded clamps on mine. Yes the BD dropped the exhaust temp 200 degrees on a hard pull, going down the road it runs 300-400 degrees cooler than stock.
    I see no signs of soot, loose or broken studs, all the gaskets appear to be intact.
    That's what I initially thought it might be, but I still think it is boost/pressure related, I will try to play with the fan and see if it has any effect.
    All the studs and nuts are intact.
  10. Rawze
    Rawze Medium Load Member
    328
    818
    Jun 29, 2013
    inmytruck
    If I had a squeal and suspected my fan belt or AC belt, then I would have cranked the truck and held a dry bar of soap against it, coating it from top and bottom a good bit, then went down the road to see if the sound went away. (My grandfather, a master mechanic, showed me this trick many years ago).
  11. Lucar
    Lucar Road Train Member
    1,396
    889
    Aug 22, 2012
    Texas
    Should the soap be olay ? Or splash wintergreen?
    Cetane+ Thanks this.
